1990 Celica GT4 st185 doesnt boost
Postby Boosted_162 » Sun Jun 22, 2008 3:51 pm
dvmv_kim wrote:okay thanks guys, but with classique71 he said the boost tap might have gone fuzzy is he talking about the boost controller or the boost source near the firewall? i took the air filter pipe of and played with the turbo fan it has no play??
Try removing the boost tap to see if it fixes the problem. Just get a pipe and replace it between the turbo compressor housing and the wastegate actuator.
st 185
Postby RBPOWA » Sun Jun 22, 2008 4:34 pm
check your fault codes, hook your factory boost gauge up and see if it reads and if all else fails drop the cat off and have a quick look at the exhaust turbine.
1989 Nissan Laurel
1989 Nissan Laurel
RBPOWA
Postby Dell'Orto » Sun Jun 22, 2008 8:09 pm
avinesh wrote:lol yea the number of cylinders do change the sound a car makes but with a broken turbo how does a 4 cylinder sound like a tractor an a six doesnt make any weird sounds just didnt understand that part
Inline 4 cylinders sound quite tractory anyway.
Postby dvmv_kim » Sun Jun 22, 2008 10:17 pm
yeah ive done that
dvmv_kim
Re: st 185
Postby dvmv_kim » Sun Jun 22, 2008 10:19 pm
RBPOWA wrote:check your fault codes, hook your factory boost gauge up and see if it reads and if all else fails drop the cat off and have a quick look at the exhaust turbine.
how do i check the fault codes? and would anyone here by any chance know where the pipe from the factory boost gauge will be i cant seem to find the pipe i cut :(
dvmv_kim
185
Postby RBPOWA » Sun Jun 22, 2008 10:32 pm
For the fault codes bridge TE1 and E1 in the diagnostics box and count the flashes of the engine light on the dash (do a search for code meanings etc). The hose you've disconnected will be the one that goes to the map sensor other wise your car probably would have boost cut with that tap, hope that helps
1989 Nissan Laurel
1989 Nissan Laurel
RBPOWA
Postby Prymal » Mon Jun 30, 2008 3:10 pm
what i meant ( sorry bout the delay been near dead with the flu ) was where you tap in the vaccum source for your boost guage . I foud with my old speco guages that the hose supplied to read boost figure , spliced into a vaccum lne via a T piece would pop off now and then , resulting in a vaccum leak , and the car going OMFG , no boost ..
Pop it back on again , with a better quality vaccum hose - and it was fine after that
Prymal
Users browsing this forum: Bing [Bot] and 8 guests
