dvmv_kim wrote:okay thanks guys, but with classique71 he said the boost tap might have gone fuzzy is he talking about the boost controller or the boost source near the firewall? i took the air filter pipe of and played with the turbo fan it has no play??
Try removing the boost tap to see if it fixes the problem. Just get a pipe and replace it between the turbo compressor housing and the wastegate actuator.
