Where to find: M11 x 1.0 nuts.
Postby method » Wed Aug 27, 2008 12:22 am
Waitemata hydraulics in auckland have most nut and bolt sizes.
PICS UPDATED DAILY
method
Postby postfach » Wed Aug 27, 2008 12:46 am
or you could save yourself the hassle, fork out and buy the bits you need from toyota......
Seriously, I don't think you're going to have any luck finding an M11 nut or bolt off the shelf in any shop in NZ. I've had a discussion with the owners of The Bolt Shop about sizes like this before and basically what they said is you're out of luck anywhere.
The only other thing I could suggest is if its aluminium/some kind of soft metal that these studs belong in, is as above, get a best fit imperial size and live with that, or drill the holes out ever so slightly and carefully hammer, or (preferably) press some M12 studs in.
postfach
Postby fivebob » Wed Aug 27, 2008 12:55 am
Try The Bolt Holder in Matamata Ph (07)888-6960.
If they don't have it, or won't make it for you, then you probably can't get it anywhere in NZ. :wink:
Postby MrOizo » Wed Aug 27, 2008 6:41 pm
fivebob wrote:Try The Bolt Holder in Matamata Ph (07)888-6960.
Awesome! i'll see what i can get from them!
Cheers.
MrOizo
Toyspeed Legend
Postby 85AW20v » Thu Aug 28, 2008 10:50 pm
I've knocked out and measured the studs from the C52 gearbox output shaft as follows:
length overall 31mm
length to head 26mm
thread length 16mm
spline diameter 8.0 to 8.5mm - slight taper over 10mm
thread pitch seems to be the same as any other nut that fits a 12mm openender.
Hope that helps.
See ya
Simon
85 MR2 20v
85AW20v
Postby MrOizo » Thu Aug 28, 2008 10:58 pm
Simon85MR220v wrote:I've knocked out and measured the studs from the C52 gearbox output shaft as follows:
length overall 31mm
length to head 26mm
thread length 16mm
Hope that helps.
Thanks alot for your help! Seems as these are too small.
I have found out that some light commercials should have this thread pattern.
MrOizo
Toyspeed Legend
Postby MrOizo » Sun Aug 31, 2008 9:22 pm
Well!!
Managed to find a wheel stud which was very close to te specs i need.
Its a 7/16 UNF stud from a holden apparently. Thread pitch measures at about 1.25 compared to the 1.0 that was stock :o
Installed anyways.,... hope it holds out :)
MrOizo
Toyspeed Legend
