Bazda wrote:I had to get upgraded valve springs.
I did heaps of dyno runs on 25psi and it was fine, did about a weeks driving on 20psi. Then one day it got valve float and bent the valve.
So I upgraded springs and have never had an issue.
Also when I did upgrade them the car felt much much stronger at high boost levels!!
TRD_ZERO wrote:
Pm them? The head specialist sad anything over about 15psi needs uprated springs. He is a head specialist he does this for a living is he wrong? But then how is gasman and flygt4 getting away with it?
Well I run just under 18psi with standard smallport head no probs. Have taken it to a couple of track days now and holds boost no probs.
How much power do you need for you the "have fun"? Kinda sounds like you are just wanting 20psi because its a nice round number?
MAGN1T wrote:Valve spring tension has got nothing to do with boost. Revs , yes. Think about it. How can they blow open?
IH8TEC wrote:25psi on std 16v springs8,000rpm and lots of abuse haha,
RomanV wrote:Because boost is a measure of pressure in the intake manifold, not pressure in the combustion chamber.
The valves'll let air into the 'other' cylinders from the manifold, if boost is forcing them open.
