Upgrading valve springs
Postby pc » Tue Sep 16, 2008 6:56 pm
Wouldn't the stronger spring make it seat more firmly while under high boost?
I would assume that the firmness of the seating should also be taken into account and not just whether or not there is enough boost to blow the valve open.
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby tsoob » Wed Sep 17, 2008 2:11 pm
Bazda wrote:I had to get upgraded valve springs.
I did heaps of dyno runs on 25psi and it was fine, did about a weeks driving on 20psi. Then one day it got valve float and bent the valve.
So I upgraded springs and have never had an issue.
Also when I did upgrade them the car felt much much stronger at high boost levels!!
Gary did my head and made the same recomendation, and as barry said its ok for a while then you get a problem, I have had so many issues in the last year or so you would be insane to "risk it" it WILL cost you more later on.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby Mr Revhead » Wed Sep 17, 2008 2:46 pm
interesting the some have issues straight away, and others never
maybe its in the prep of the head?
as MAGN1T said earlier, if your springs take 35 psi to move them, and your running 20psi, there shouldnt be an issue.
Postby Bazda » Wed Sep 17, 2008 3:11 pm
Some people have issues, some dont, I guess its how old your springs are and how worn they are.
measure them first, if they are near the factory specs should be ok.
Going from the blacktop manual it says they should be:
Maximum squareness: 2.0mm max
Free length: 48.97mm
Spring tension: 149-165N (33.5-37.0lbf) @ 37.7mm
Postby ~SlideWays~ » Wed Sep 17, 2008 4:02 pm
TRD_ZERO wrote:
Pm them? The head specialist sad anything over about 15psi needs uprated springs. He is a head specialist he does this for a living is he wrong? But then how is gasman and flygt4 getting away with it?
Well I run just under 18psi with standard smallport head no probs. Have taken it to a couple of track days now and holds boost no probs.
How much power do you need for you the "have fun"? Kinda sounds like you are just wanting 20psi because its a nice round number?
~SlideWays~
Postby Bazda » Wed Sep 17, 2008 4:27 pm
the 16v springs are better cos they are bigger and stronger.
20v springs are small and weak!
Postby TRD_ZERO » Wed Sep 17, 2008 6:30 pm
Im wanting to run 20 psi as my engine is capable of (well atleast i thought it is was) and thats only every now and again. As other guys one here running the same setup not having any issues
TRD_ZERO
Postby IH8TEC » Wed Sep 17, 2008 7:24 pm
25psi on std 16v springs :lol: 8,000rpm and lots of abuse haha,
Postby RomanV » Wed Sep 17, 2008 8:24 pm
MAGN1T wrote:Valve spring tension has got nothing to do with boost. Revs , yes. Think about it. How can they blow open?
Because boost is a measure of pressure in the intake manifold, not pressure in the combustion chamber.
The valves'll let air into the 'other' cylinders from the manifold, if boost is forcing them open.
Postby ~SlideWays~ » Wed Sep 17, 2008 8:24 pm
IH8TEC wrote:25psi on std 16v springs :lol: 8,000rpm and lots of abuse haha,
Hey how much torque is your motor making?
~SlideWays~
Postby TRD_ZERO » Wed Sep 17, 2008 10:12 pm
I saw the head reconditioner and he is adament that i shouldnt run anything over 12-13psi and 15psi is a really bad idea. No testing of my valve springs have been done yet. Ive been reccomended to the guy by people on here since he supposibly know his stuff about 4ages, maybe only the dirty 16vs though. :lol:
TRD_ZERO
Postby Bazda » Wed Sep 17, 2008 10:13 pm
who is this guy btw...
Postby TRD_ZERO » Wed Sep 17, 2008 10:38 pm
IM not bad mouthing this guy i dont really know him ive only heard good things about him hence the reason i went there and he is fantastic to deal with. Just questioning his valve spring theory. Cyliner head shop sunnybrae rd Glenfield. I think thats what it is called.
TRD_ZERO
Postby Bazda » Wed Sep 17, 2008 11:22 pm
Oh yes we know the guy very well.
He does know heads, but he prob doesnt know much about 4agtes and how much power you can actually put through them.
Postby TRD_ZERO » Wed Sep 17, 2008 11:30 pm
Yeah ive been told by alot of pople in the industry to go there for head work. Super friendly too. Just dont want to get vlave springs if i dont have to.
TRD_ZERO
Postby MAGN1T » Thu Sep 18, 2008 12:07 am
RomanV wrote:Because boost is a measure of pressure in the intake manifold, not pressure in the combustion chamber.
Not when the pressure in the combustion chamber is higher than boost pressure.
35 pounds on the seat.
1 inch or so diameter.
.78 or so square inches.
About 50 PSI to force open.
That means manifold pressure would need to be about 50 PSI greater than the combustion chamber.
It will never happen.
Steve
Computers make you go mad.
MAGN1T
!USER HAS BEEN BANNED!
Postby rollaholic » Thu Sep 18, 2008 8:06 am
i think the concern is more about the valves on cylinders that arent on a compression stroke being forced open, say for example on exhaust when theres little pressure in the cylinder.
Postby Bazda » Thu Sep 18, 2008 11:17 am
Postby MAGN1T » Thu Sep 18, 2008 11:36 am
Obviously written by the sales and marketing department.
Don't stop there though, you also NEED new cams and they'll never work properly without titanium retainers, they're absolutely essential.
Triple large fries FTW.
72 pounds of seat pressure? it depends on the pressure inside the cylinder at the time.
For as long as people have been modifying cars, there's always been others trying to sell parts that aren't needed.
Steve
MAGN1T
Postby fivebob » Thu Sep 18, 2008 2:06 pm
Actually I think the reason behind it has nothing to do with the valves being forced open. Rather, it is that the required seat pressure to move the valve has been reduced, therefore the valve will accelerate faster and you will then get more valve loft.
The higher you rev the engine the greater the valve loft. Which at some point in time will result in valves meeting pistons and the inevitable bent valve. :evil:
Users browsing this forum: Bing [Bot] and 23 guests
