1990 MR2 ALTERNATOR PROBLEMS!!
Postby GDII » Fri Dec 26, 2008 7:15 pm
Double post
1990 SW20 MR2
Previous 1990 EE90 Corolla
GDII
Postby GDII » Fri Dec 26, 2008 7:18 pm
Got the alternator problem again.
Bought a new alternator 3 months ago and now it won't charge.
I have the exact same problem as I had before. Replacing the alternator seemed to fix it. But now I am not sure if its the alternator itself. It could be other wiring.
Symptoms are:
Battery charge light on.
Cat converter light on.
Engine fan light on.
Voltmeter gauge needle at the bottom of the shaded area.
1990 SW20 MR2
GDII
Postby Alex B » Fri Dec 26, 2008 7:34 pm
You checked the belt? I dont envy you if its alternator again. :lol:
Postby johndoe1025 » Fri Dec 26, 2008 8:01 pm
the other warning lights are because of low voltage, if you brought it new, it should have a warranty. take it back.
EP82 GT-went mega hard for completely stock, 15.09 quarter, gone now :(
AE111 Levin BZG current! 4AGTE next? you never know....
johndoe1025
Postby GDII » Fri Dec 26, 2008 9:22 pm
Belt is fine. I check it regularly.
Warning lights make sense.
Think I will sell this car. Had so many problems with it.
1990 SW20 MR2
GDII
Postby Adamal » Sat Dec 27, 2008 10:18 am
Sounds like the alternator is a dud. Was it rebuilt or just someone parting a car out?
Postby Alex B » Sat Dec 27, 2008 3:24 pm
Was a recon one apprently.
Postby matt dunn » Sat Dec 27, 2008 6:48 pm
I can repair them as am an Auto Elec,
but really dpends on what's wrong with it as to the $$$.
Also if it's had a bad patch up on the rotor, they are basically a throw away job.
They can be repaired properly and sucessfully, but not after they have been butchered.
Postby GDII » Sat Dec 27, 2008 6:49 pm
Its a recon. Took it back to get it sorted.
1990 SW20 MR2
GDII
Postby GDII » Sat Jan 03, 2009 3:07 pm
The diode went pop so they gave me another whole alternator.
I still have my original alternator, I think that just needs new brushes. So I may get that fixed up as a backup if I ever have problems again.
1990 SW20 MR2
GDII
