Help, Starter Motor continiously spins
Postby Matty104 » Tue Jan 20, 2009 10:01 pm
tested the started motor and its fine, and wires were right to start with , so we now think it is a fault in the ignition wires somewhere, so still need a test lanp to tes it and should be al go from there, will keep you posted,
cheers for the help guys
'Tron E30 Massif
89 BMW 325sci
Matty104
Postby 3T-Rona » Wed Jan 21, 2009 10:50 am
If the clicking was the start relay then your problem is between the relay and the starter, which is easy enough to by pass.
The other poss. is that the clicking is your acc. relay clicking off as you turn the key to the crank position (no acc power while cranking)
PM me for anything autoelectrical, Info or jobs etc....
3T-Rona
Postby ChaosAD » Wed Jan 21, 2009 9:47 pm
I vote installing a starter relay permanantly as you can get volt drop across the ignition switch.
ChaosAD
