spacers
Post by rollaholic »
have rocked slipons on heaps of cars, never had a problem
Distrb
Regular Poster
Contact:
Post by Distrb »
read http://www.lvvta.org.nz/stdWheels&Tyres.pdf
in particular sections 2.5(1); 2.5(2); 2.5(3) 2.5(7)
also sections impacted by spacers 2.2(8)
In short: Spacers or adaptors must be certified, no matter how thick. They must also be secured to the hub or wheel face, no matter how thick
Sure people have got away with all sorts of things in all sorts of places (i've even seen people get away with certing slip on spacers). But if you want to know what the current official documents on the topic say, then read the above link.
Post by bluemaumau »
good info disturb.
are ae101 hubcentric diameter 73mm
im away from the car tonight
so the hub centric ring should fit the hub or wheel
hub is 54mm and rim is 72mm
im guessing the hub ..as it then makes it, i guess, more part of the hub?
postfach
Post by postfach »
It should fit both, the spacer should be snug on the hub, the wheels should be snug on the spacer.
Most people overlook this when fitting aftermarket rims, but you'll notice a factory rim always fits tightly over the hubcentric ring on the hubs of the car they came out on.
i wouldnt imagine they make them like that.
so should i go hub or rim?
Mr.Phreak
Contact:
Post by Mr.Phreak »
They should be the same as the hub, and from the sounds of it, your wheels need some spigot rings
postfach
Post by postfach »
Yeah you can buy rings to fit between your hub/spacer and rim from most wheel/tire shops
callum
Post by callum »
my corolla is certed for slip on spacers
Post Reply
