Dell'Orto wrote: Gen 3 pistons are quite good and cheap.
deaf_rattle wrote:shot peen the rods
Boosted_162 wrote:I see gen 1 shares the same CR (8.5:1) so not sure if pistons are the same? Gen 2 has a lower CR of 8.1:1
frost wrote:is there any difference in valve cut outs on the gen2 and gen3 pistons? seeing as they have different heads. valve angle maybe?
Adydas wrote:If you really have money to spend and want to do somthing the BEST thing i did was buy some tein adjustables.. Not only does the car handle better but it also feels faster beacuse it reduces the saggy feeling when you plant your foot..
iOnic wrote:Unless you want under 300whp I can't see any reason why you'd choose the Gen 3 over the Gen2 you already have. They are both as capable as each other after this point.
fivebob wrote:iOnic wrote:Unless you want under 300whp I can't see any reason why you'd choose the Gen 3 over the Gen2 you already have. They are both as capable as each other after this point.
Because,IMO, Gen III is easier to get HP out of and will cost less in the long run if you're going for under 400HP.
iOnic wrote:I know you wouldn't need to crack the engine open for that power level but the OP has already stated that he wants to get the engine rebuilt either way.
Yes the oil system is better on the Gen3...but does that make the Gen3 more capable of producing 350hp than the Gen2 or easier to make 350hp with? As far as I can tell that's a point on the reliability side of things and not so much on the power production side.
fivebob wrote:The ease of modification to get to sub 400HP is all about the ports in the head... IMO the Gen II ports are far too big for good power delivery, and removing the TVIS (which is what a lot of people seem to do) just make sthe engine even more peaky. The Gen III's smaller ports keep the air velocity up so the torque curve is much nicer. At extreme power levels (500HP+) the smaller ports are still just as good and there seems to be little difference in max power output between the engines.
thornz wrote:Well, realistically I am not after huge power, always just fancied a reliable street driven 350hp, which obviously is not that hard to achieve. So I guess a pretty basic build would be all that would be required. Dont know if I would be worried about cams etc. With that power figure in mind, would it pretty much be a case of making the internals bulletproof, forged rods and pistons?
fivebob wrote:deaf_rattle wrote:shot peen the rods
Why bother they're already strong enough and I think they might even be shot peened from the factory.
