e10 Corolla Engine Conversion?
Postby DriftSpecStarlet » Fri May 08, 2009 1:15 am
Lol.. No you CANNOT bolt an engine mount to the vehicle it MUST be welded in and not just a Lil whorey weld from a supercheap $100 welder
Best off sourcing an engine mount and going to a panel beater or an engineer and getting him to do correct welds, then you wont be hassled when getting it certified
Toyota Celica ST185
Big f'n front mount,
Bodykit (actually looks decent)
Lowerd on blue Springs
T3/T4 Turbo
BOV
All the gadgets!
DriftSpecStarlet
Location: Gisborne, New Zealand, Earth, Universe, Milky Way.
Postby 20v_rollaboy » Fri May 08, 2009 1:31 am
DriftSpecStarlet wrote:Lol.. No you CANNOT bolt an engine mount to the vehicle it MUST be welded in and not just a Lil whorey weld from a supercheap $100 welder
The standard engine mount on the cambelt side is actually bolted to the chassis.
Phanatic, get the mount welded properly in place, although when it comes time to change the mount I'm not sure what you're going to do :?
20v_rollaboy
Postby DriftSpecStarlet » Fri May 08, 2009 1:38 am
Yes but thats standard from manufacture, Changing/Adding his mount is a modification which needs to be done correct :)
And im sure he wouldnt want to be going back too an E series and A is common enough so permanent should be sweet?
Toyota Celica ST185
T3/T4 Turbo
BOV
All the gadgets!
DriftSpecStarlet
