3S bellhousing question
Postby frost » Mon Jun 22, 2009 9:28 pm
yeah i noticed that too, but everything seems to mash together ok.
i've now gone gen4 3sgte and will get a proper ring gear for it.
Postby rxtoy » Sun Nov 01, 2009 8:28 pm
sooooooooooooo......................
trying to buy a Y bellhousing off a mate for this and i'm getting sick of the bellhousing collection i'm slowly amassing, he's got a 2Y with 4 speed, these the same as 4Y with 5 speed?????
its a convoluted story.
Matt
current rides:
76 stout
77 B1600 13B J port
rxtoy
Postby frost » Sun Nov 01, 2009 9:10 pm
4 speed? steal case box? if so then no. wrong for you.
4 and 5 speed bell housing's don't swap over,
your after 2y 3y 4y 5speed w55 box only.
Postby KinLoud » Mon Nov 02, 2009 7:42 pm
4 speed might be a W45 or G45... alloy box.
Ken
Postby rxtoy » Mon Nov 02, 2009 10:30 pm
hmmm, i'll have to check it out.
are hilux box's w55????? i always thought the were something different. that would be handy though, leave me with a spare box for the stout in case of breakage.........................
Matt
current rides:
76 stout
77 B1600 13B J port
rxtoy
Postby evil_si » Tue Nov 03, 2009 7:14 am
hiluxs are generally a W series or a G series, and the input face is very similar they are interchangable,
on the 1uz adaptor plates that i do, they w series fits the hilux box they just have to be ground out a little to clear the g series input cover
evil_si
Postby AE25 » Wed Nov 04, 2009 2:07 am
yep w56, w59, g52, r151
do you also have to space the release bearing forward on the carrier to get a better clutch fork angle if you do not shave the 1s, 2s, 4s, 1c, 2c, 3c bellhousing with the 3s engine.
the gen5 beams altezza 3sge apparently has a different offset flywheel which fixes most of the usual issues converting 3s to rwd. and i read that the std dual-mass flywheel have issues and better to replace with aftermarket steel flywheel. you'd still need the double row spigot bearing with this i do assume?
also did you know there is a factory rwd 3s? comes in a sr40g and sr50g liteace as a 3sfe. unfortunately not a twincam. only the sr40g came with a manual with G52 according to toyodiy.com also distributorless!
looks like this
http://page18.auctions.yahoo.co.jp/jp/auction/w27996695
http://page2.auctions.yahoo.co.jp/jp/auction/b104932567
E2 & E7 fanatic
http://www.toycrazy.net
AE25
