Bigger cc injectos on N/A 4age BT
Postby ~SlideWays~ » Tue Jul 21, 2009 10:04 am
BZG|Bling wrote:
Quirky wrote:standard blacktop is 8500 rev limit, so somewhere there
LOL got proof?
Maybe you got a limited spec one as every other standard blacktop cuts at around the 7800 mark.
I thought it was 8300? Our silvertop goes well past 7800.
~SlideWays~
Postby XSVWGN » Tue Jul 21, 2009 10:15 am
hard to explain but .....if when the car is running and u very very slowly turn the key off towards the accesories (only a matter of degrees) you can turn the euc and eletrics off but still have the engine run. A guy in lower hutt showed us and his reved past 10,000!!!
Cambo1 now has the car of had the car for a while. Had a couple of rebuilds in its time haha
2008 Kia rio - work car
XSVWGN
Postby Crampy » Tue Jul 21, 2009 11:07 am
XSVWGN wrote: you can turn the euc and eletrics off but still have the engine run. A guy in lower hutt showed us and his reved past 10,000!!!
:lol: :lol: :lol:
You on crack or something dude?
If you turn the ECU off on an EFI car, the car stops running. No injector pulses, no ignition pulses, so the engine wont run. Simple.
Also, rev counters aren't the most accurate things at times, so a car indicating that it's going 10,000rpm, might only be going to 8k in reality.
Crampy
Postby XSVWGN » Tue Jul 21, 2009 11:11 am
:lol: :lol: :lol:
haha nah nah mate. well im 600% sure this can be done as i have done it before and my brother does it every now and again to see if it will die but alas 250000 kms of thrashing and it still goes. I may just have to take a video of it then ;)
XSVWGN
Postby Crampy » Tue Jul 21, 2009 11:16 am
Well I tell you for a fact, if the motor still runs, it wont be turning the ECU off.
It might be powering some stuff down, but I can't see what.
I'm also not entirely sure why you'd want to do this either. The stock rev limiter is there for a good reason.
Crampy
Postby Crampy » Tue Jul 21, 2009 11:19 am
XSVWGN wrote: well im 600% sure this can be done...
I've told you a trillion times.... Don't over-exaggerate :lol:
Crampy
Postby cogent » Tue Jul 21, 2009 11:25 am
Doesn't the ignition barrel acc switch control power to a relay that then powers various accessorys?
So if you cut power to the relay you cut power to everything running off that relay, and if you give power to that relay you give power to everything connected to it.
in short:
cogent
Postby Mr Revhead » Tue Jul 21, 2009 11:26 am
either:
a: bullshit is prolific here
or
b: aftermarket ECU, ie mines or sard with no rev limit. and extreme luck rod hasnt exited stage everywhere
but please, dont stop. my lol factor is high today :lol:
Postby xsspeed » Tue Jul 21, 2009 12:33 pm
either way am keen for video of engine at 10k.
Postby AceSniper » Tue Jul 21, 2009 4:07 pm
:lol:
10k std :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
To many kids on this forum
AceSniper
Postby Crampy » Tue Jul 21, 2009 4:10 pm
Indeed.
Drugs are bad... mmmm kay.
Crampy
Postby GTCRSHR » Tue Jul 21, 2009 4:28 pm
XSVWGN wrote:my brothers silvertop trueno reved out to 10000;) With the ignition in the trueno you can slowly turn the key around to off (from engine running) vey very slowly and it will turn off the eletrics and rev limiters but the engine will still run. You can hear it go past 7,8,9000rpm!!! its insane!
Not good for the engine clearly but the trueno is a piece of sh*t so gets a good thrashing!! As the engine were originally designed by Yamaha with moterbike essentials inmind i believe these things can rev out very far
Im sure someone will correct me if i am wrong...
Matt
Nothing to see here ...
GTCRSHR
Postby kramer2202 » Tue Jul 21, 2009 8:04 pm
hahaha this thread turned out to be quit amuseing lol and thanks for help on the injectors ill just keep the standard ones :lol:
kramer2202
Postby frost » Tue Jul 21, 2009 11:33 pm
it could turn out true. stranger things have happened. on blue moon nights.
it could be a forged motor and didnt even know it. how can you tell unless you crack it open.
i once found aftermarket cams in a 4age shortblock that was pulled out of a crashed daily. the owner didn't know until after i pull them out and told him.
i even suspect the springs where aftermarket.
edit. also i can take the key out of the barrel when its in ignition and the car still runs. ...only cos its a old ass toyota with tooth pick key and molested barrel.
Postby XSVWGN » Wed Jul 22, 2009 1:04 am
for everyone out there here is a video of the car being turned off and then driven ...and yes you can hear it hit limiters!! my bad!! had it going last year and fanging down the highway and turned the key back on to see the Rev meter at 8600 rpm and the speen at 165 in 3rd
http://www.youtube.com/watch?v=UMzW4FURzPM
XSVWGN
Postby thegreatestben » Wed Jul 22, 2009 1:33 am
Rev counter in my Aw11 sees the blacktop hit a pretty high redline.
Here's some incar footage at taupo but you can see the needle is buried in red 8O (AW tach goes to 9000rpm)
http://www.youtube.com/watch?v=xHtKDd87v1I
(may have to wait for video to be processed)
thegreatestben
Postby 79rolla » Wed Jul 22, 2009 11:27 am
not all of the electronics have been turned off.
our hiace you can pull the key out and it keeps driving (no the ignition isint $&#$%) dad gave me the shits when he did this. and didint put it in wen i told him to, then we got to the end of the straight and the steering lock came on when he turned tho corner :roll: :roll:
past: AE82 FXGT
79rolla
Postby Mr Revhead » Wed Jul 22, 2009 1:41 pm
XSVWGN wrote:for everyone out there here is a video of the car being turned off and then driven ...and yes you can hear it hit limiters!! my bad!! had it going last year and fanging down the highway and turned the key back on to see the Rev meter at 8600 rpm and the speen at 165 in 3rd
:lol: so you can turn the dash off.
a little different from your first post!
Postby XSVWGN » Wed Jul 22, 2009 1:53 pm
correct and my apploogies. You loose everything like lights, wipers etc etc. but i am still certain of the other trueno reving out to 10,000. Will find out more about it
Sorry for the spamming of the thread to by the way guys
Matt
XSVWGN
Postby Loudtoy » Wed Jul 22, 2009 8:56 pm
Boost_4_Life wrote:wow. definitely gonna try that one :roll:
Tried it, turning the key very slowly from on to off on my car made it well .... turn off. Strange that :lol:
TS Member sine 2001
Prado To tow stuff with
Rodeo to do work stuff in
Loudtoy
Users browsing this forum: Bing [Bot], Google [Bot] and 20 guests
