4agte injector sizes
Postby matt dunn » Wed Sep 30, 2009 12:28 am
IH8TEC wrote:
i would tend to agree, i think willie pushed about the max out of the 550's he had with just over 300kw atw.
I run 550's in my 7AGTE at the start,
got to 380hp atw ( whatever that is in kw ) with a wee raise in rail pressure on the dyno before the flywheel came off.
Postby ~SlideWays~ » Wed Sep 30, 2009 8:55 am
Speedtech tune on 4agte:
365cc (4agze) @ 13psi = 149kw atw
510cc (evo 1-3) @ 17psi = 212kw atw
Standard fuel pressure and the injectors where the limiting factor on each.
~SlideWays~
Postby evil_si » Wed Sep 30, 2009 5:18 pm
ok so i have a few options at the moment,
550cc rx7 injectors easy to fit, will bolt straight in
850cc rx7 injectors, are side fed so i will need to make / modify a rail to suit
any one out there currently using 850's?
had been thinking about using standard ones and jam a couple of 1000cc injectors in the intake, but i figure id better not rob to many bits from my rx7
evil_si
Postby mjrstar » Wed Sep 30, 2009 5:39 pm
evil_si wrote:ok so i have a few options at the moment,
I don't rate the chance of 850's giving you a healthy idle, but it might be worth a try..
^^Interesting also that the 510's would only make 212kw atw. I would have thought they would be good for around 230.
current cars:
Evo 4 230Kw atw
1971 mini.
79 bugeye 245kw atw.
mjrstar
Postby IH8TEC » Wed Sep 30, 2009 5:43 pm
different size motors though, thats 285ish kw atw.
Postby matt dunn » Wed Sep 30, 2009 10:50 pm
IH8TEC wrote:different size motors though, thats 285ish kw atw.
doesn't really matter, you need X amount of fuel to make X amount of hp on any motor.
Postby loose_unit » Wed Sep 30, 2009 11:21 pm
Just gotta be careful with rx7 550's that you get a well matched set as they are made in pairs. Out of 6 that I had my tuner was only happy with 3 of them even after cleaning etc, and he wouldnt put them in my car. I ended up going with evo 7 560's as they apparently have a really good spray pattern. Ive got an old g1 v4 lem and have had no issues with the 560's in there.
91 GT Starlet 5efte
231kw atw @ 18 psi
12.13 @ 185kph
loose_unit
Postby ~SlideWays~ » Thu Oct 01, 2009 9:12 am
Thats what the tuner said, he normally see's 220kw on a mitsi so put it down to possibly lower pressure in the toyota fuel system vs mitsi.
Thats with a Walbro (sp?) 500hp jobbie.
212kw's is plenty for 920kg though :lol:
~SlideWays~
