OH NOES!!!!! Radiator Foam
Postby thegreatestben » Tue Aug 31, 2010 11:44 pm
Other option which I don't think has been mentioned is using a leak down test, it's obviously got some gas in those bubbles, it'll set off a teekay test straight away if that's combustion gasses creating the bubbles. For some reason I found that using Redline water wetter at an overly concentrated mix would foam up really easily.
Have you tried tasting it :lol:
thegreatestben
Postby rollaholic » Wed Sep 01, 2010 2:03 pm
CAMB01 wrote:What makes you such a so called expert at blown head gaskets Steve?
he has inflicted many on himself over the years from what i've read.
ps do what lloyd said!
pressure gauge trick only useful if you are sure there is no air in it
