gmacrae wrote:$&#$% here we go again, lets all jump on the goodie too shoes bandwagon
1I1 wrote:sik_gt_starly wrote:get some fat friends, problem solved and wont have to spend a cent
Or bags of cement
wde_bdy wrote:tsoob wrote:shortening shocks is pretty cheap and really painless, I have an engineer that works in the unit next to me, he can do a pair in about 30 mins.
Ad then that needs cert as well....
wde_bdy wrote:No, shorter stroke shocks are fine but shortening a shock by machining requires cert for pretty obvious reasons. Very easy to get it wrong and if you have the shaft fail on a macpherson strut front end it won't be pretty. It is a modification that is not excluded from the cert requirements.
Callum
tsoob wrote:Actually you are wrong Callum, I have my certifier here right now and he has just gone over it with me.
As long as it still uses the original mounts, does not travel out (bump steer) and does not go under 100mm your suspension is legal.
