want my car just a touch lower
Postby RomanV » Wed Nov 17, 2010 3:04 pm
A spring is just a bent piece of steel.
Cutting a spring does not unleash nuclear energy or kill kittens or tear a hole in the space time continuum.
The net affect of cutting a spring shorter, is increasing the spring rate - Which is is generally half of the idea anyway, or what people want to do when lowering their cars regardless.
I disagree about cutting the end of the spring that has all of the coils bunched close together though, as these are what give the suspension droop and act like keeper springs.
Better off shortening from the other end, to reduce from the 'hard' spring rate part of the spring.
compressing the springs reduces the spring rate, which is not ideal when your car is now lower.
If the springs are no longer captive, or the shocks are no longer able to appropriately control the spring,, this is when it starts to get ugly.
And IMO the reason for the 'no cut springs' rule.
Postby wde_bdy » Wed Nov 17, 2010 3:49 pm
At the end of the day you can choose to do it, however if recommending it to others the least you should do is advise of the potential consequences. It's like a lot of car mods, everyone is happy to say such and such is great but never give you the downsides. So for cut springs, compressed springs or shortened shocks etc you need to mention the need for cert and that if you choose not to cert your insurance is out the window and in an accident you could face some fairly stiff penalties. Then it becomes an informed choice and anyone doing is taking their own risks. Personal opinion on cut or compressed springs though is why would you bother? Custom wound are so cheap these days and generally don't need cert like the other options do.
Callum
wde_bdy
Postby Bling » Thu Nov 18, 2010 12:35 am
gmacrae wrote:$&#$% here we go again, lets all jump on the goodie too shoes bandwagon
:lol:
Yeah I bet you have a FTP sticker on your car too? What a tough guy.
At the end of the day, people are free to do whatever they like. But there is nothing wrong with people liking or disliking something. Cut springs is always something that divides the camps. No need to get upset if people have different views to your "right" view..
Informing people of potential downsides to car mods is not something i'd consider a bad thing. Bandwagon or not.
Just get some customs made imo.
On the topic, is it possible to get springs made that sit lower but still remain captive when not under load? Or does that just equal soft springs that would be crap? :lol: A way to avoid shortening shocks, or just not worth it?
Postby tsoob » Thu Nov 18, 2010 12:59 am
possible, but the ride would be average and they would most likely sag over time.
shortening shocks is pretty cheap and really painless, I have an engineer that works in the unit next to me, he can do a pair in about 30 mins.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby h8wrxs » Thu Nov 18, 2010 3:19 am
1I1 wrote:
sik_gt_starly wrote:get some fat friends, problem solved and wont have to spend a cent :lol:
Or bags of cement :wink:
i do actually know someone who filled the spare tyre well with cement in a s1 rx7 thinking it would help give him traction and lower it at the same time....
oh and cheapest option for the query = $29 grinder from bunnings :d
or just buy adjustys
The four seasons in Australia consist of "$&#$% it's hot", "Can you believe how $&#$% hot it is?", "I won't be in today because it is too $&#$% hot" and "Yes, the dinner plate size spiders come inside to escape from the heat."
h8wrxs
Location: travelling to candy mountain with my magical leoplurodon
Postby wde_bdy » Thu Nov 18, 2010 9:44 am
tsoob wrote:shortening shocks is pretty cheap and really painless, I have an engineer that works in the unit next to me, he can do a pair in about 30 mins.
Ad then that needs cert as well....
wde_bdy
Postby coupekiwi » Thu Nov 18, 2010 11:36 am
Cut the springs.
If you have inactive coils cut them out half at a time.
Don't cut from the other end as that will reduce the spring constant much more than taking out the inactive coils.
They should still be captive. If not next wof get the shocks shortened.
Keen to cut the top off the strut and weld it back on with 30mm missing.
coupekiwi
Postby TazzieDevil » Thu Nov 18, 2010 11:50 am
Take the springs out, then wyhen you go for a wof, put them back in
Get In, Sit Down, Shut Up & Hold On
TS Profile
It wasn't Me, it was the one armed Man!
TazzieDevil
Postby tsoob » Thu Nov 18, 2010 4:46 pm
only if you go below 100mm
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby wde_bdy » Thu Nov 18, 2010 5:07 pm
No, shorter stroke shocks are fine but shortening a shock by machining requires cert for pretty obvious reasons. Very easy to get it wrong and if you have the shaft fail on a macpherson strut front end it won't be pretty. It is a modification that is not excluded from the cert requirements.
Callum
wde_bdy
Postby rx7guy » Thu Nov 18, 2010 6:06 pm
http://www.lvvta.org.nz/stdSuspensionSystems.pdf
I cant find anything about shortening shocks?
The torque band is wide and the road is narrow
rx7guy
Postby Flannelman » Thu Nov 18, 2010 6:09 pm
chop the top of the shock tower and weld in a new section. raises both shock and spring keeping ride quality the same yet lowering the car. make sure the cut and shut job is accurate as it affects camber/caster if its not square. and make sure the person can weld!
Flannelman
formerly known as Affroman
Postby tsoob » Thu Nov 18, 2010 9:18 pm
wde_bdy wrote:No, shorter stroke shocks are fine but shortening a shock by machining requires cert for pretty obvious reasons. Very easy to get it wrong and if you have the shaft fail on a macpherson strut front end it won't be pretty. It is a modification that is not excluded from the cert requirements.
Callum
What are the obvious reasons..?
I don't know of anyone who can shorten a shock in their backyard, you need a lathe and some kind of idea how to use it, its not just a matter of hack something off and way you go.
A skilled engineer (such as the one that I use) would be very unlikely to 'get it wrong'
As far as certification goes until you go under 100mm or you have an adjustable shock you are not legally required to cert. As long as the thing is captive and has no leaks it is legal.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby Mr.Phreak » Thu Nov 18, 2010 9:46 pm
Mr.Phreak
Postby wde_bdy » Thu Nov 18, 2010 9:51 pm
Have you actually read the rules?????
Try reading them again, it specifically lists what you are allowed to do without cert. You might notice the AND in front of every single requirement. If it's not listed, it isn't allowed. :roll:
You will notice it says direct replacement shock abosorbers, NOT shocks some lathe jockey has cut the top off to keep your springs captive.
Callum
wde_bdy
Postby tsoob » Tue Nov 23, 2010 10:42 am
Actually you are wrong Callum, I have my certifier here right now and he has just gone over it with me.
As long as it still uses the original mounts, does not travel out (bump steer) and does not go under 100mm your suspension is legal.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby shihad » Tue Nov 23, 2010 11:13 am
tsoob wrote:Actually you are wrong Callum, I have my certifier here right now and he has just gone over it with me.
lets not forget the law is interpreted differently by diff cert guys.
try ringing up all the cert guys and ask this simple question can a car be certed under 100mm its a 50/50 what they will say back.
getting bottled by the friendly Oamaru locals for not doing skids - Coupe Life
shihad
Postby wde_bdy » Tue Nov 23, 2010 11:21 am
Your certifier can say what he wants, it is written in black and white. You may only fit shocks that are a direct replacement, cutting the top off and re-threading it in order to keep your springs captive is clearly not a direct replacement. Why don't you ring up NZTA and tell them you want to cut and re-thread the main part holding your suspension to the car in a macpherson strut front end and see if they say it is sweet to go through a WoF which is only a visual inspection?
Callum
wde_bdy
Postby tsoob » Tue Nov 23, 2010 7:06 pm
awesome well being that he deals with lvv all the time i think ill take his advice on this one. thanks for your input however
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby 85AW20v » Tue Nov 23, 2010 7:57 pm
And what if the shocks aren't replacements but the originals that are being modified? Getting picky I know......
See ya
Simon
85 MR2 20v
85AW20v
Users browsing this forum: No registered users and 158 guests
