Wheel spacers
Postby metal_sean_head » Sun Nov 07, 2010 10:27 am
rollaholic wrote:did they decline the claim as well?
Yeah i think so. It went through the other parties insurance as it was entirely their fault. It eventually got fixed after a lot of fluffing around.
VTEC: All of the lag and none of the boost.
89 AE92 FXGT
Big Port Redtop
TVIS!
19.8@32kph
metal_sean_head
Postby h8wrxs » Sun Nov 07, 2010 6:29 pm
legally they can decline the claim, but if you crashed your car because you swerved to miss a dog, i doubt they would ping you for 2mm spacers
maybe if it had bald tires and cuttys etc they might
i know from experience AMI doesnt decline you on crap like that though
h8wrxs
Postby cat007 » Tue Nov 09, 2010 10:38 am
I thought the little slip on ones are ok as long as they're 5mm or so?
Postby Bazda » Tue Nov 09, 2010 10:50 am
If its the rears your having issues with. On the corollas there is another way you can space it out, but you will have to space out the whole stub, therefore need to space out the caliper the same amount. This is all hidden and you can space up to 5mm with no probs.
As for wheel spacers, I thought as long as they are hub eccentric they should be fine and with longer wheel studs.
car
Postby docTRD » Wed Nov 10, 2010 8:10 pm
On the subject of wheel spacers, I have some 25mm spacers on the front of my jzx90 and they are a bit wide and have made me go from a 225 tyre to a 205 so they don't stick out from the guard. Can I get the spacers machined down to 15mm (which is as far as I know the minimum for wheel spacers with studs) and the studs put back in? I just want to reduce my track by about 10mm so I can run the bigger tyres. I think the hub centre is 60.1mm which is not easy to find spacers in. The ones I have are 66.1mm with a ring to suit my hub.
Daily : st191 corona liftback mmm room
Project : Jzx90 mark2 Tourer V
--- wtd: corolla GT ae92 sedan ---
"Mum i knw its another wreck, i only got it so i can put the seats in the lounge" YEAH RIGHT
docTRD
Mo Joe
Postby wde_bdy » Wed Nov 10, 2010 8:37 pm
http://www.redlineperformance.co.nz/?ac ... part=26989
Not hard to find at all and probably cheaper than modding yours.
Callum
wde_bdy
Re: car
Postby Bazda » Wed Nov 10, 2010 8:50 pm
docTRD wrote:On the subject of wheel spacers, I have some 25mm spacers on the front of my jzx90 and they are a bit wide and have made me go from a 225 tyre to a 205 so they don't stick out from the guard. Can I get the spacers machined down to 15mm (which is as far as I know the minimum for wheel spacers with studs) and the studs put back in? I just want to reduce my track by about 10mm so I can run the bigger tyres. I think the hub centre is 60.1mm which is not easy to find spacers in. The ones I have are 66.1mm with a ring to suit my hub.
give it to a machinist, be pretty easy to do, take about 40 mins on a manual lathe.
Postby Bling » Wed Nov 10, 2010 8:59 pm
cat007 wrote:I thought the little slip on ones are ok as long as they're 5mm or so?
http://www.nzta.govt.nz/resources/virm- ... ation.html
Have a read on what you can and can't cert etc.
You can't have any spacers in any form without a cert in any case. any any :lol:
Postby RickGT » Fri Nov 12, 2010 11:23 pm
so anything over 12.5mm spacer on each side is elligal "aparently"
MX73 GLXi Cressida 1JZ-GTE
EP91 Glanza V
RickGT
Postby wde_bdy » Fri Nov 12, 2010 11:29 pm
No, changing wheel offset by more than 12.5mm is illegal without cert and ANY spacer is illegal without cert. Once you cert it though you are up to whatever the certifier deems safe in terms of offset (there are some limits) and can have slip on spacers up to 25mm or bolt on up to 27mm.
Callum
wde_bdy
Users browsing this forum: Bing [Bot], Google [Bot] and 14 guests
