MAGN1T wrote:How many times do you need to be told?
As for bubbles being "normal" ?
How many new cars do that?
Steve
sergei wrote:shroud or no shroud it should not overheat any way on idle.
What is happening is either or all:
your head gasket is blown (MAGN1T)
your block is full of rust that is being pushed into "clean" radiator and ultimately blocking it.
It is very common problem in NZ as kiwis just keep adding water to the cooling system, thinking that since there is no sub zero temperatures you don't need antifreeze (and/or being cheap asses).
It is a syndrome of "I'll sell it after a year" thing that average NZ car sees.
rollaholic wrote:its hardly surprising that the needle is pushing over half with that kind of treatment. its not designed to deal with the heat created by so many revs without some airflow over the radiator, particularly with the smaller radiator you fitted. why do you think so many cars shit themselves on the skid pad?
and you mentioned air bubbles in your very first post
if its sitting at half with normal usage i'm not sure why this topic is still going?
MAGN1T wrote:It's like a bunch of primary school kids. kids with no idea giving advice to other kids with no idea.
Your headgasket is leaking from the cylinder to the water jacket, that's what the bubbles are.
The exhaust gasses dissolve in the water that you keep adding.
That makes the coolant acidic.
So now you've got an electrolytic cell, one electrode being aluminium, the other iron, and a weak acid for electrolyte.
So the iron and aluminium corrode quickly, the leak gets worse and the radiator gets clogged up with sludge.
So what's the point in doing anything to the radiator? it's the bubbles that cause the corrosion / sludge, the corrosion makes the bubbles bigger.
Steve
rollaholic wrote:learning to ignore magn1t is the first step in the twelve step program
he does get it right sometimes, but if you call BHG on every overheating thread its bound to be the correct call occasionally.
kinda like the AA diagnosing every breakdown they cant jump start as faulty fuel pump
plus hes used to mitsis, where BHG is right more often than not
Dragger_Dan wrote:par·a·graph /ˈpærəˌgræf, -ˌgrɑf/
[par-uh-graf, -grahf]
–noun
1. a distinct portion of written or printed matter dealing with a particular idea, usually beginning with an indentation on a new line.
2. a paragraph mark.
3. a note, item, or brief article, as in a newspaper.
–verb (used with object)
4. to divide into paragraphs.
5. to write or publish paragraphs about, as in a newspaper.
6. to express in a paragraph.
tsoob wrote:Dragger_Dan wrote:par·a·graph /ˈpærəˌgræf, -ˌgrɑf/
–noun
+1
Dude please use some punctuation its really really hard to read.
avinesh wrote:i have overheated my supra many times as well....well over two dozen times and many of them were till the red mark and it still doesnt have a blown head gaskit and it produces 426kw at 22.5 psi, two of those times it overheated was when i was doing a burnout at meremere and the serpentine belt came off because of crappy after market pullies and many times when i was at full throttle, now the aristo being a stock car and only boosting 10psi makes me wonder how its more prone to blowing its head gaskit with far less power and the same engine??? i took it for some extensive test drives last night and to my understanding under boost (have raised it to 15psi now) it should overheat rather quickly if it has a blown headgaskit but im surprised it didnt even budge.....i have never driven this car as hard as i did last night just to see if it overheats and surely enough with the new radiator there was no overheating where as on the old radiator the car would overheat in the 2nd round you step on the accelerator, correct me if im wrong steve but wouldnt the headgaskit leak more under 15psi of boost and hard driving and cause the car to overheat and loose a bit of coolant because i just checked the coolant level right now and its to the max in both the reservoir and the radiator, my understanding is combustion leaking into the coolant would pressurize it, one making it over heat and two pushing the coolant out of the system especially under the harsh circumstances i put it under last night, you said the corrosion must be caused by the headgaskit but the car doesnt seem to have corrosion in the radiator, its more like small pebbles i think the previous owner put some stop leak init thinking there was a leak somewhere (radiator or headgaskit) but made things worse because the bloody things and clogging up the radiator now, i have done very extensive tk testing on it an have finished two bottles of the liquid so i probably hold the record for tk testing performed on a single car and had nothing come up even when i had bubbles appearing in the system, i basically did the test with the car revved up and bubbles appearing and nothing, did it on idle nothing, did it from cold to hot and still nothing even today nothing. Some conclusions from last night though, the car doesnt overheat with a smaller radiator and only one fan compared to two fans on the old radiator and this time it was under much much more stress which should have made the car overheat very quickly in case of a blown headgaskit because i know from past experience that headgaskits get worse not better if blown and under-boost they get happy and make your needle go to h very quickly.
