4agze blue smoke video up
Postby Dell'Orto » Tue Apr 12, 2011 11:22 pm
It could be the PCV valve, but I bet it isnt
Postby Bling » Tue Apr 12, 2011 11:36 pm
The guy sold you it with "a stuck valve" could be anything. If your mechanic says its gone... it's probably gone :( My guess is you got it cheap?
Postby KinLoud » Tue Apr 12, 2011 11:54 pm
I am the guy who sold it to you.
I told you very clearly that the ENGINE NEEDED REPAIR.
I told you it MIGHT be a stuck valve.
You got it for a very low price.
Your friends who seem to have much better knowledge about engines came with you to look at the car. They recommended that you should buy it.
You seem to be surprised that the engine isn't running very well.
Ken
Postby KIPH8N » Wed Apr 13, 2011 12:54 am
KinLoud wrote:I am the guy who sold it to you.
Ken
Yes i agree.
I have rebuilt the head (new valve seals and guides,head has been polished) and the compression seems to be fine but its still smokeing. I have no idea what else could be the problem. I thought it would be a PCV valve but where exactly is it located on a 4agze engine.
That might be the suspect of the blue smoke.
Thanks
KIPH8N
Postby Bling » Wed Apr 13, 2011 12:58 am
All makes sense now. Amazing how the TRUTH changes the situation aye!
The engine just sounds poked. A mechanic has told you this. You got it knowing it had engine issues. Who determined it was only the head that needed repairs? Did you get the whole engine checked properly? It's all guess work until you get it checked properly. Ever played pin the tail on the donkey? :lol:
Postby allencr » Wed Apr 13, 2011 8:56 am
What oil you running?? Go thicker if it isn't already a straight 40.
Time to try one of the fabolous snake oil magic in a can additives, you got nuttin to lose.
Sorry about the valve stem seals & guides wild goose chase. I have no idea why so so many interweb recommendations about smoke & oil usage think that that's it. Good luck.
Also, doubt that it has a PCV valve, unless its a carb'd engine.
allencr
Postby Mr. Mainstream » Wed Apr 13, 2011 10:46 am
was helping out a mate with his B6T. didnt smoke like you say,idled rough thou like a subaru. had zero compress on one cylinder yes zero, and it was simply a seized valve. easy fix for those engines
ive had the same engine smoke like a train before, Ie Stream train, was just a $11 PVC valve, so could be worth a shot
75 MK2 Ford Escort L 2.1L
Various Others
Mr. Mainstream
Postby Quirky » Wed Apr 13, 2011 12:57 pm
I dont think the 4agze has a pcv valve?
Hello There
Quirky
Postby KIPH8N » Wed Apr 13, 2011 2:00 pm
yeah i looked for the pcv valve i couldnt find it.
Does a ae101 4agze have a pcv valve?
I opened the throttle body today and i saw oil in it as well as inside the inter cooler piping.
Where could the oil be coming from?
I think it oil in getting in the engine through the valve and thats why its smoking blue.
KIPH8N
Postby CelicaGT8 » Wed Apr 13, 2011 6:02 pm
Temp sensor
CelicaGT8
Postby allencr » Wed Apr 13, 2011 7:49 pm
What's the compression?
KIPH8N wrote:Where could the oil be coming from?
There is NO valve.
It's an old tired thrashed engine with worn rings & lots of blowby.
If it was only smoking at high rpm & high G left handers, then modifying its crankcase vent would help.
Again, sorry that you were taken by someone(obviously a mechanic in name only) that claimed it was seals & guides causing it. Good luck.
I sincerely apologize for being a dumb $&#$% if the supercharged version of the 4AG has a PCV or 2.
allencr
Postby MAGN1T » Wed Apr 13, 2011 11:26 pm
Broken ringlands from overboosting.
Did you give it a compression test ?
Steve
Computers make you go mad.
MAGN1T
!USER HAS BEEN BANNED!
Postby KIPH8N » Thu Apr 14, 2011 9:57 pm
I ringed up mankau toyota today they told me there are 2 pcv valve's on a 4agze engine. They can get it from japan which is around 80 dollars. But i dont know where the PCV valve is on a 4agze engine. Can anyone help me find it because if it is blocked then it will have those symptoms.
Some people say it has a PCV valve and some say they dont.
Again its a map sensored ae101 4agze.
KIPH8N
Postby d1 mule » Thu Apr 14, 2011 11:20 pm
read this, you should be able to track it down (assuming it has them) once you actually know what they do/look like
http://en.wikipedia.org/wiki/Pcv_valve
d1 mule
Postby KIPH8N » Fri Apr 15, 2011 1:16 am
I found one but cant find the other one
KIPH8N
Postby gt4dude » Fri Apr 15, 2011 1:51 am
do you have the top mount intercooler on? it might be underneath it?
its a plastic nozzle that fits into a 14mm (approx) hole in the top of the valve cover, it will have an 8-10mm rubber hose coming off that going to the intake manifold
basically anything thats connected to your valve cover and goes to your intake is part of the oil breather system, i cant think of anything else like it
セリカGT-FOUR ST205 中期型 (Chuuki)
200AWKW / 370NM
gt4dude
Postby gt4dude » Fri Apr 15, 2011 1:53 am
And for some reason no AE101 trueno or levin appears on ToyoDIY,... Weird.
200AWKW / 370NM
gt4dude
Postby 2LTR Rona » Fri Apr 15, 2011 10:20 am
gt4dude wrote:And for some reason no AE101 trueno or levin appears on ToyoDIY,... Weird.
http://www.toyodiy.com/parts/g_J_199410 ... ACMXR.html
AE101 with 4AGZE
2002 Altezza, 1974 KE25
2LTR Rona
Postby KIPH8N » Fri Apr 15, 2011 1:17 pm
gt4dude wrote:do you have the top mount intercooler on? it might be underneath it?
Yes i found that one under the inter-cooler. But toyota says theres another one.
KIPH8N
Postby KIPH8N » Fri Apr 15, 2011 1:18 pm
AE101 with 4AGZE
Thanks for that mate.
Yes there are two PCV valves.
On toyo DIY it has
http://www.toyodiy.com/parts/p_J_199410 ... _1201.html
KIPH8N
