Name this steering arm
Postby AWShev » Sat Apr 09, 2011 11:04 pm
hub appears 2 be an mr2 item either aw or sw as early 1's r the same
unsure on the steering arm cant say ive seen 1 on anything comon
as 4 the ball joint looks like corolla as yems has stated from the likes of a
ae111 but lots of corolla use the same joint
AWShev
Postby soopachargen » Sun Apr 10, 2011 7:21 pm
I would put money on that being a caldina ball joint... the car is a caldina, if the factory balljoint fits you wouldn't bother changing it, and thats what it looks like on toyodiy
When in doubt, down and out.
soopachargen
Postby CelicaGT8 » Sun Apr 10, 2011 8:59 pm
Yea the ball joint will be the easy part to find, so many toyota ball joints in that style, Hub is sw20 mr2, but what is the steering arm off, simular to an rx7 style one.
CelicaGT8
Postby CelicaGT8 » Thu Apr 21, 2011 5:59 pm
Im sorry, but BUMP
Maby it is AE86 or simular, could anyone measure the distance between the mounting points for me?
CelicaGT8
Postby soopachargen » Thu Apr 21, 2011 7:01 pm
the mounting points on some ce7* arms (which fit ae86 RCA's) that we have in the shed have 85mm between the two bolt centres
soopachargen
Postby CelicaGT8 » Fri Apr 22, 2011 9:37 pm
Thanks, i happen to have a gen3 sw20 here so i will check - In the dark, rain, cold. God bless winter
CelicaGT8
Postby CelicaGT8 » Fri Apr 22, 2011 10:02 pm
Yea the spacing measures the same. Could be worth a shot, CE7x, same as a ke70 but has a diesel engine?
Just need to find some and do a test fit. Anyone have some cheap ones lol
CelicaGT8
Postby QikStarlie » Fri Apr 22, 2011 10:30 pm
will have to dig it out, but i have a single (cant remember what side) ae85/6 non power steer arm if thats any help. the ps arms are shorter
QikStarlie
