buying a early 90's soarer?
Postby rollaholic » Fri Aug 12, 2011 10:30 am
theres more than one, i was just first!
(im looking at you adamal)
Postby deaf_rattle » Fri Aug 12, 2011 12:10 pm
rollaholic wrote:theres more than one, i was just first!
lol, he still has alot of teeth too. crazy
i was actually including travel distance to tyre shop in my calculation. :lol:
Postby holden_fan2005 » Sat Aug 13, 2011 1:16 am
Mr.Phreak wrote:
holden_fan2005 wrote:Note: They tend to chew the gas and tyres though.....
You might want to check your alignment/LCA bushes
Correct, tyre usage for me is due to burnouts :lol: Generally if you're nice on the go pedal things should be fine.
If you do end up getting a soarer I have a set of 2000km old kyb struts and stock height springs for the right price (less than trade new).
holden_fan2005
Postby Si » Sun Aug 14, 2011 12:46 pm
If its a well-used one you can also have problems with the way the door handle is mounted - its quite weak, and with older hinges you can end up pulling the thread out of the handle mount. \
Plenty of easyish mods make them better - like going to LS400 caliper/rotors.
Current: , '96 SubaruImpreza
Si
Postby Makaveli » Sun Aug 14, 2011 6:53 pm
Celsior with 1UZ-FE I used get something like 14 Litres consumption per 100km on 98 Octane. This is combination of city and motorway driving. With open roads this could possibly fall to like 12.5 to 13 Litres per 100 km.
Makaveli
