4agte pushing buckets of oil out of breathers (solutions?)
Postby Crucible » Wed Jan 25, 2012 8:41 pm
Vertigo wrote:also try adding a flap at the oil return inlet, not sure how effective it would be, but might help stop oil sloshing up the pipe around corners and causing more issues. definitely needs to be above oil level if at all possible tho.
What about a ballvalve? or possibly a valve that can be opened by cable from inside? like a heater tap?.
If you had one on the return, you could close it seperating sump from the catch can when your on the track. Open it back up when its not running in the pits so oil can return.
Like cambo1 suggested, its the crankcase pressure stopping oil returning from can->sump, you literally have crankcase pressure coming from r/c covers and from sump meeting at the can where oil is sitting, with a ballvalve can->sump would be totally seperate.
The breathers/small filters used on most catch cans becoming blocked with oil as suggested makes sense also and wouldnt help with the situation..
Crucible
Real Life Mechanic
Postby Grrrrrrr! » Wed Jan 25, 2012 10:29 pm
Drysump pump.. problem solved. Others created :)
Grrrrrrr!
Postby CXGPWR » Wed Jan 25, 2012 11:21 pm
I never had any oil breathing problems in my 4agte, 16v smallport, more or less bog standard, had cams, 14/15psi, 9000rpm redline, never breathed much and that did a few hard laps round manfield without any oil issue. never filled a catch can and the catch can was not plumped back into the sump.
Check ring end gap & piston clearance tolorance. Also check ring orientation, make sure they are stacked correctly to minimise blow by.
CXGPWR's 1985 Toyota Trueno Racecar Spec
Build Thread
Discussion
CXGPWR
Users browsing this forum: Google [Bot] and 26 guests
