power stats for st205 with aftermarket ecu- 3sgte
Postby sergei » Fri Jul 13, 2012 10:17 pm
jbod wrote:
Al wrote:gen2 blocks are supposedly thicker than gen3 blocks. However gen2 blocks still let go, just around the water pump rather than in a cylinder wall.
If you are building a motor you would be mad not to build a 98+ 5S block.
Meh the 5s lacks oil squirters. I'd probably buy a short block.. There is a revision of the st205 block in 1998, I'd wonder if the thick/thin wall issue is resorected.one would assume so as they wouldn't randomly revise it if there wasn't an issue, , getting a shortblock removes the need to reli on a rebuilder to aside the head work
Additionally brand new short block is cheaper than proper rebuild, as well as you are sure it is not monkeyed up (as usual in NZ).
Postby Al » Fri Jul 13, 2012 10:45 pm
You can machine in the oil squirters if you really want them. I wouldn't bother. There are two 9 second MR2's in the US that don't have them on their 5S builds.
I'd still want the 10% extra increase in displacement. Quicker spool, more torque, more power everywhere.
Al
Postby jbod » Sat Jul 14, 2012 4:12 pm
Yeah 3k for shortblock. so that plus head rebuild, gasket set, oil pump. would be reasnbale. tho what i want to know is the revision of the 205 block better? toyota don't know, and ive talked to some hlepful people there not the halfwits .hmmmm
jbod
Postby Akane » Sun Jul 15, 2012 1:04 am
Anybody here that actually made enough power to worry about oil squirters?
:S
Postby Al » Sun Jul 15, 2012 1:32 am
13 second gt4s are fast bro.
Al
Postby jbod » Sun Jul 15, 2012 8:24 am
Akane wrote:Anybody here that actually made enough power to worry about oil squirters?
:S
I suspect it not only aids in lubrication but the cooling of pistons to. I personally wouldn't leave them out,tho I think we've gone abit off topic here from ecu tunes
jbod
Postby strx7 » Sun Jul 15, 2012 9:52 am
they are really only required for long period high output engines ie: race track & rally.
