BZG|Bling wrote:
Ok so skip a few steps. For the Celica fans out there, how hard is it to drop the engine / trans / front suspension out? I'm currently removing the old engine piece by piece, and it's a nightmare.
TIA
BZG|Bling wrote:
Also Sergei, when you say almost complete, what have you removed? Ideally i'll just bolt new engine up to trans 100% complete and lift it into place.
Thanks for the info
BZG|Bling wrote:Ah yep, got most of that sussed. Just thought there might be part of the engine i'd have a problem installing in one go. With the limited space, I just want to be able to install the engine/box/everything else in one hit and then connect everything to it. Rather than have to torque up engine bits in place.
Is the power steering only under pressure when running?
Will probably spend tomorrow removing everything bolted on to the front so I don't damage bits.
Grrrrrrr! wrote:I'll be interested to see how you get on with this, let me know if you end up deciding the current head/motor is scrap, there are several bits in it I may have a use for.
Users browsing this forum: Google [Bot] and 29 guests
