BZ Touring. Manual conv. Pulling to the left under acc. help
Postby FST4RD » Sat May 18, 2013 2:14 pm
Just a random thought...
You haven't got a bent suspension arm or perhaps a slogged out bush? If you were accelerating and had a slogged out bush one wheel might pull off in a different direction?
Wheel alignment?
1983 Mitsubishi Starion
1995 Subaru legacy GT SW
FST4RD
Postby Mr Revhead » Sat May 18, 2013 2:50 pm
Its been for an alignment and check up so those things should be covered.
I was thinking same as 85aw20v but struggling to think how a helical diff can act like that.
It is helical isn't it? Or have you fitted a clutch pack diff? If it'd clutch pack it'll be the diff
Postby RobertC » Sat May 18, 2013 8:38 pm
:D :D :D :D :D
Problem solved!!! Well sort of...
Took out the current gearbox which was a C56-04C. (factory AE111 super strut LSD box) (Helical?)
Replaced it with a C56-04A. (factory MS ae111 box) Car now drives perfectly... :)
So ideas on what could be wrong with the LSD box?
Assuming it was in working condition when I received it the only thing that could have possibly damaged it would be when I was trying to put the drivers side drive shaft in with the AUTO hanger bearing bracket bolted to the block (this meant the shaft was trying to go in the box on an angle)
MRAE111 wrote:ok thanks guys but wen u dont have trmpets i think the air flow quickeer into the throttle bodies
RobertC
Postby Mr Revhead » Sat May 18, 2013 8:48 pm
It pulls hard left which suggests less drive to the left axle.
I have no idea how that can happen in a helical type :?:
Postby sergei » Sat May 18, 2013 10:40 pm
Mr Revhead wrote:It pulls hard left which suggests less drive to the left axle.
catastrophic failure locking up one side completely, while leaving other freewheeling.
Postby RobertC » Sat May 18, 2013 11:33 pm
But I could still leave two solid marks in the paddock. (so both wheels were certainly getting drive)
RobertC
Postby MrOizo » Sat May 18, 2013 11:39 pm
An open diff can spin both wheels if on grass. Try again on seal ;)
MrOizo
Toyspeed Legend
Postby Mr Revhead » Sun May 19, 2013 12:34 am
I'd like to think he would notice a wheel not turning at all :lol:
Postby RobertC » Sun May 19, 2013 12:58 am
both wheels 100% did have drive. (Put it in gear while up on axle stands)
And the part of the paddock was the driveway so had a gravel base. Was surprisingly grippy. Trying to replicate it with the open diff will certainly result in a one wheeler peeler :lol:
RobertC
Postby d1 mule » Sun May 19, 2013 1:06 am
gravel and grass sounds very slippery to me. I dont know the ins and outs of FWD diff stuff so i havnt commented till now, but it sounds exactly the same as when i blew a locked diff in my old ae85, had 100% drive to the right wheel and 0% to the left, similar symptoms. I would be betting on a shagged diff
d1 mule
Postby Mr Revhead » Sun May 19, 2013 1:09 am
A $&#$% diff could still turn a wheel that's not loaded though.
Postby RobertC » Sun May 19, 2013 1:21 am
considering changing the gearbox has fixed the problem there must be a problem with the old gearbox. The diff being the only bit that's going to cause the pulling to one side.
So the question now is should I pull it apart? :o
Haynes manual says 5 stars 8O
Will there be visually broken bits?
RobertC
Postby Mr Revhead » Sun May 19, 2013 10:04 am
Start googling how a helical diff works? You could drain the oil and check that. If there's broken bits there should be bits in the oil
Postby thegreatestben » Sun May 19, 2013 12:13 pm
There's more than one way to split a C series box. I did it the sneaky way when changing the bellhousing on my MR2. That doesn't involve removing 5th gear and gives you access to the Diff. If it doesn't necessarily need to go back together it'll be a good learning experience.
thegreatestben
Postby 85AW20v » Sun May 19, 2013 12:22 pm
thegreatestben wrote:There's more than one way to split a C series box. I did it the sneaky way when changing the bellhousing on my MR2. That doesn't involve removing 5th gear and gives you access to the Diff. If it doesn't necessarily need to go back together it'll be a good learning experience.
The box will come apart about 20mm leaving 5th gear on and you can get a spanner in through the gap to undo the bolts that hold it together. I put my LSD in to my C52 this way. Can't remember what it is that's bolted up....
See ya
Simon
85 MR2 20v
85AW20v
Postby RobertC » Mon May 20, 2013 10:59 pm
Well....
Drove 200km yesterday with the non lsd box and it turns out it still veers to the left slightly. (power or no power)
So I'm thinking there is still something wrong with the car drive line.
My brief understanding of a torsion diff makes me think if one of the shafts is misaligned it could be causing an uneven torque input hence a funny output from the diff .
Previous owner of the lsd box talked to who he purchased the car from and it definitely was not doing anything funny before it was sent to me.
the open diff box not being torque sensitive meaning alignment is not so crucial hence no torque steer.
RobertC
