what kinda mods can i do to my Toyota CELICA SS 2.0 1994 to
Postby fangsport » Thu Jan 19, 2006 9:57 pm
Mmm, Boost wrote: Those bi-linear piezo's are garbage, they crap out after pulling 14,000rpm too many times
...........and that, my friends is what happens when you skimp on quality. i know the 2.0l Celica motor will never rev as freely as the 4K Mmm, Boost refers to, but come on, i fitted a bi-linear piezo unit to the old 186 Holden in-line 6 and was pulling bigger numbers.
Mmm, boost, did you forget to run the 3 strontuim sheiled earth earth wires when you installed it?? you should get at least 17,000 out of a 4K :(
fangsport
Postby Santa'sBoostinSleigh » Thu Jan 19, 2006 10:01 pm
17000 is a bit steep to be pushing it really
on a 3SGE, which im assuming you have agressor, i woudnt be looking at going over around 13000-13500rpm
I had the 3SFE set at 12550rpm and she hummed, never crapped out once
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby fangsport » Thu Jan 19, 2006 10:09 pm
Santa'sBoostinSleigh wrote:17000 is a bit steep to be pushing it really
Santa, for our viewing pleasure, please advise the readers your ACTUAL hp with the CT26 on the said 3sfe. i know we all told the guy with the Caldina that 450 was a crock, but us Toyspeeders have a habit of shying from the truth.
fangsport
Postby Santa'sBoostinSleigh » Thu Jan 19, 2006 10:11 pm
huh i never mentioned CT26.....i was talking about bi-linear piezo electric pulse wave generators
Santa's Mega Sale
Postby Dell'Orto » Thu Jan 19, 2006 10:14 pm
No, that was only on the running in period! The running in time for the piezo recommends 4 pulls to 10,000, 4 to 12,000, 4 to 14,000 and one final rip up to 16, and its meant to be good to go - mine let go on the 3rd pull to 14,000! Was not amused. Saved up for the Mk3 Flux capacitor with adamantium housings, and its really made the difference. I estimate at least 1400hp at the spigot bearing.
Postby Santa'sBoostinSleigh » Thu Jan 19, 2006 10:17 pm
adamantium housings or audotorium (sp?) housings?
Santa's Mega Sale
Postby fivebob » Thu Jan 19, 2006 10:18 pm
Mmm, Boost wrote:The running in time for the piezo recommends 4 pulls to 10,000, 4 to 12,000, 4 to 14,000 and one final rip up to 16, and its meant to be good to go - mine let go on the 3rd pull to 14,000! Was not amused.
There in lies your problem. You're not supposed to pull to 14,000, you're supposed to push. Pulling at that speed results in friction burns, as you no doubt found out :twisted:
Postby fangsport » Thu Jan 19, 2006 10:22 pm
Santa'sBoostinSleigh wrote:huh i never mentioned CT26.....i was talking about bi-linear piezo electric pulse wave generators
did you not have them fitted before and after the a CT26 thus making it quad polar?? must have been mistaken for someone else.
has anyone fitted an adjustable dementia valve or a lobotomy gauge to a 3S?? i heard it makes them go hard!!
fangsport
Postby Santa'sBoostinSleigh » Thu Jan 19, 2006 10:26 pm
no fangsport, if i fitted the famous CT26, theres no way that the car would ever have traction
plus i wanted to stay NA,
by adding the special blend of lithium grease and hydrofluro-monodioxin (found in pascals marshmellows) in the sump, ensured that the oil stayed fluid and did a superb job of lubricating the piezo internals
(pm me if you want my special blend recipie - id rather not put it on a public forum)
Santa's Mega Sale
Postby Dell'Orto » Thu Jan 19, 2006 10:43 pm
Santa'sBoostinSleigh wrote:adamantium housings or audotorium (sp?) housings?
Adamantium, they phased out the audatorium housings in the 2nd rev MK2...they just couldnt handle the high rpm output as well.
fivebob wrote:There in lies your problem. You're not supposed to pull to 14,000, you're supposed to push. Pulling at that speed results in friction burns, as you no doubt found out :twisted:
What! The intructions clearly said pull!! See, cheap products have poorly worded instructions.
Aggressor, seriously, save for the MK3 F/C, its truly worth while
Postby barryogen » Fri Jan 20, 2006 7:17 am
fangsport wrote:shoehorn the radiator from a '67 (has to be 67) VW Bettle on a 45 degree angle in front of bumper and grille (i can't stress enough, '67 Beetle/45 degrees) 800+hp easy
those 67 VW beetle radiators had amazing flow and cooling rates, it was almost like there was no radiator there are all.
barryogen
2ZZ Guru in training
Postby darkmyst » Fri Jan 20, 2006 10:57 am
Remember mate...
Every morning when you start your car, make sure to be red lining it for a few seconds, that way it cleans the engine + warms it up...
Remember though, the bigger the tip, the more the free flow, so 6inch tip = More freeflow... meaning the regulation of the flux capacitor will run much smoother and wont fail you when you're going back to the 90's. know what I'm sayin'...
Anyway, what you have to realise is the flux capacitor does need to be maintained regularly, that means, make sure to clean it with a toothbrush, or something similar :) and there you have it, my 2 cents.
Currently - Installing sounds/doorpanels
darkmyst
Postby HELBND » Fri Jan 20, 2006 11:30 am
Some great info here - I vote FAQ
this thread makes me cringe every time.. but its funny as hell
HELBND
Postby Wildcard » Fri Jan 20, 2006 11:33 am
Mine just arrived today!
Wildcard
Toyspeed Founder
Postby Santa'sBoostinSleigh » Fri Jan 20, 2006 11:51 am
ooooh you got the industrial version!
get that thru one of your contacts in Stratford?
i drive past the place every day on my way to/from work!
Santa's Mega Sale
Postby fangsport » Fri Jan 20, 2006 12:29 pm
Wildcard wrote:Image
whoa, nice install. if i pay the fare, can you come down and do the install on my new car. it'll a couple of weeks before the engine is back in, so any time after that would be mint. pm me back.
fangsport
Postby barryogen » Fri Jan 20, 2006 12:33 pm
I already did it yesterday my time, a month last tuesday your time... you seemed really happy with the results, a solid low 9s in your first run down the 1/4
barryogen
Postby fangsport » Fri Jan 20, 2006 12:40 pm
low 9's, is that all! did you forget to put all 3 earth wires on???
you should be able to do -15's in your car Barry. i managed to get to the finish 10 seconds before i left the start line last time i went down the 1/4.
fangsport
Postby barryogen » Fri Jan 20, 2006 12:52 pm
fangsport wrote:low 9's, is that all! did you forget to put all 3 earth wires on???
sorry, I missed the - symbol, low -9s
you had traction issues, but solved that by adding some d8 tracks
barryogen
Postby MrOizo » Wed Jan 25, 2006 1:04 pm
ooo000ooo the pilot model :D
just like the one i saw years ago - havent changed much
MrOizo
Toyspeed Legend
