Whats the rule on having a surge tank inside the car, as my car is a hatchback, and dont have backseats so everything is open if you know what i mean.
I think it should be fine as long as you use proper fittings and proper braded fuel lines.
CAMB01 wrote:Hey all can someone give me in great detail how extract 400 flywheel horsepower out of a 4AGZE please?
So far i have a GZE block which is bored out 0.5mm with toyota 0.5mm oversized forged 9.0:1 pistons
GZE crank
Poilished shotpeened and balanced rods.
Going to balance the rotating assembly
Have a small cylinder head and manifold.
Dont have a turboport or an exhaust manifold yet.
0.8mm TRD steel shim head gasket.
Will be using an aftermarket computer, dont know what yet.
Drifter4ag wrote:heres my simple setup for you ...
8.0:1 ze block
small port head
standard intake manifold
action dan ex manifold
Evo2 cooler
440cc injectors
HT18 turbo / Skyline ex housing
14psi
Megasquirt
182kw@wheels and mung beans of torque
Easy as pie for great numbers
OH YEAH .. STOCK BLUETOP FUEL PUMP STILL
CAMB01 wrote:Well ive had the rods modified, debeamed, shotpeened and balanced.
getting the crank etc balanced.
I have ARP stud kits for the mains, head, and rod bolts.
oversized forged pistons.
I'm thinking it should be reliable aye?
Bazda wrote:
I thought u wanted 400hp (300kw) at the flywheel.....
