Blacktops when cold
Postby Lanius » Mon May 29, 2006 8:36 pm
demis wrote:when it is doing it badly your cant accrelate at all, some times i have to pull over to let traffic pass
so its not a matter of pushing it to hard when cold :)
Wow, mines nowhere near as bad as that 8O
Lanius
Postby Mr Revhead » Mon May 29, 2006 8:50 pm
yeah id say you have a real problem, not what we are talking about
Postby demis » Mon May 29, 2006 10:48 pm
i think it is related
:roll:
EX 1984 Corolla FX GT (AE82) 1st gen 4age
EX 1996 Corolla BZ touring (AE101) 5th gen 4age -LSD
EX 1997 Carib Z touring (AE111) some 4afe muck
Ex 2000 Fielder S (ZZE122)- Its BIG RED
2002 Corolla Ts (ZZE122) Mr ~ Ts
demis
Postby astrae » Sat Jul 01, 2006 11:53 pm
Has anyone worked out whats causing this?
I bought my car from a dealer in Jan 05. I noticed it hesitating at about 3-4 rpm when warming up. Sometimes it was a slight hesitation and others it would hardly accelerate at all.
I took it back to the dealer and it had 3 days at the Auto electrician. Of course by the time I got it down there it was hot and wouldnt do it. It took 3 days of testing and they found a problem with the oxygen sensor.
This was replaced with a brand new Toyota part. It never did it again...
Till now.
In the last week it has started doing it again. Sometimes a slight hesitation. Other times it wont go past 4k rpm. Its almost feels like a rev limiter.
If I take my foot off the gas a few times it normally sorts itself out and won't do it till next time the car is cold. If I leave my foot where it is, the revs just stop climbing. Tonight it took about 10 seconds to pull away. THis is with only a small amount of throttle.
It is definitley not a miss fire. I'm sure its related to fuel and the oxygen sensor leaning it out? or something along those lines. I did think the knock sensor at one time but dont know how much this could effect things?
My car is a 96 BZG, engine pretty much standard. K& N panel filter (factory when I first had the prob) leads & plugs checked by auto elect.
I cleaned the throttle bodies yesterday, no change (like i did the first time)
The dealer paid the auto electician bill the first time... I cant afford to go back.
Anyone got anymore ideas
astrae
Postby Chickenman » Sun Jul 02, 2006 12:40 am
Has to be ECU related? Feels like it's retarding the timing for some reason.
I got sick of it so I just sit there until it comes off high idle before I go anywhere. Finishing work at 11pm doesn't help either.
Anyway,
Still getting a bit of detonation occasionally on 98, has anyone knocked the timing on a BT back a degree or two and noticed a difference?
Baby Jesus
Chickenman
I Am The Walrus!
Postby matt dunn » Sun Jul 02, 2006 1:02 am
I run mine a couple lees than factory, but we only run 96 ( or is it 95 now?)
Matt
Postby astrae » Sun Jul 02, 2006 1:04 am
Matt
I've only ever run mine on 98...
astrae
Postby matt dunn » Sun Jul 02, 2006 1:06 am
astrae wrote:
Matt
Untill now we could not Get 98 here, and now there is only a select few that have it.
Matt
Postby ROBODISCO_20v » Sun Jul 02, 2006 1:59 pm
I am asuming you guys warm your cars up before you drive them :?:
My first toyota an AE92 FXGT used to run pretty bad when cold so I let it warm up for a few minutes one day before I drove it & problem solved. I've scince done it with all my cars & have never had a problem with hesitation or miss firing. I just asume 4AGE's dont like being driven when cold.
In some casese here though it probably has something to do with faulty temp sensors or thermostat being stuck open
ROBODISCO_20v
Postby astrae » Sun Jul 02, 2006 2:32 pm
ROBODISCO_20v wrote:I am asuming you guys warm your cars up before you drive them :?:
The funny thing is mine doesnt seem to do it when dead cold. It does it more often if I come back to its semi warm. Last night the temp guage was at a 1/4.
astrae
Postby malc » Sun Jul 02, 2006 3:23 pm
Just thought I would add, mine does it too.
A split second hesitation every now and then
mine is a 97 bz-g
I test drove another before I got mine, the other one did it worse, which was part of the reason why i didnt buy it. The car had been driving for at least half an hour before I drove it so it wasn't an issue of not being warmed up.
malc
Postby AceSniper » Sun Jul 02, 2006 9:36 pm
could be the o2? I put a new one in awhile back an it ran better but now its giving lean readings to the ecu again (my guess carboned up) meaning the ecu's throwing alot of fuel on that isnt needed
AceSniper
Postby demis » Sun Jul 02, 2006 10:19 pm
i was thinking it was somthing to do with the temp sensor for the ecu as mine seems worse in the winter months, to me it seems to be adjusting the timing when it is hesatating again mine dosent have to be stone cold
some times it will do it after leaving the car for about 10 min after a long drive
demis
Postby dotdog » Sun Jul 02, 2006 10:23 pm
Sweet, swaping the sensors round should prove if its a electical fault. Mine seems really bad at the mo with all the cold arse wheather, would be real nice to find the problem now
Daily Ride - 00 Subaru WRX STi RA 12.7@113
Project Car- 89 Toyota Starlet Turbo S 95.1kws
Ex Ride - 85 Toyota Starlet Si with 4efte, 1990 Nissan Pulsar GTiR 150Kw/atw, 97 Toyota Levin BZR
My Profile: http://toyspeed.blakjak.net/profiles/profile.php?id=589
dotdog
Postby QikStarlie » Sun Jul 02, 2006 10:52 pm
dotdog: just put a 2et in it man
QikStarlie
Postby MR2SIK » Mon Jul 03, 2006 1:15 am
Its not just the blacktops doing it, Over the past month or so my 1990 3sgte has been doing the samein the mornings on my way to work, always sorts itself out within a few minutes tho, pressing down on the accelerator gave the same effect as driving with a blown knock sensor, boost goes up, induction noise is loud revs hardly climb and speed doesnt.
and for the record i normally stay off boost for the whole trip to work in the mornings, its just been feeling sluggish lately so when i put my foot down to compensate, i noticed this...
2011 Ford Mondeo tdci.
1990 MR2 GT garage queen
MR2SIK
Postby RomanV » Mon Jul 03, 2006 3:52 am
My old gen 2 3S in my MR2 did exactly the same thing some times.
I thought it perhaps had something to do with the fact that it had worn valve stem seals. (Anyone else here with problems, notice a puff of smoke out the exhaust on start up? much oil consumption?)
So I figured that the spark plugs were getting gunked up, and it wasnt firing all too well.
Postby astrae » Mon Jul 03, 2006 2:18 pm
I've just been back to the auto electrician where my car went when the O2 sensor was first replaced. They said its unlikely it could be the o2 sensor with only 25,000 km on it.
THey said it sounds more temp sensor related.
Demism the price of my o2 sensor was about $360 + gst. That could be trade price as the dealer paid for it.
I'm going to to a bit of maintenance this week (plugs, fuel filter) and have it booked in at the auto sparky on monday. Hopefully I can sort out what the prob is before then. $67 an hour at the sparky...
astrae
Postby AceSniper » Mon Jul 03, 2006 8:16 pm
hate to tell ya but revhead can do them for less than half of that
AceSniper
Postby astrae » Mon Jul 03, 2006 8:38 pm
doesn't matter to me, I didnt have to pay for it, the dealer did. If it does turn out to be the problem I might get in contact with him.
astrae
