LSD?
Postby TRD_ZERO » Sun Jan 21, 2007 8:31 pm
North Shore
TRD_ZERO
Postby flygt4 » Thu Jan 25, 2007 8:58 pm
i have 2 e51's on my garage floor now
it appears that ae92 gtz E51 most likely non-lsd has a hole about 25mm diameter you can see right through the axle holes.
ae92 gtz E51 definately lsd has a hole about 10mm diameter you can see right through the axle holes.
flygt4
Postby crispy'86 » Fri Jan 26, 2007 7:07 am
now that's a definite answer we allw ant to hear, time to get measuring
crispy'86
Postby flygt4 » Fri Jan 26, 2007 10:41 am
havent done exact measure yet, thats just a quick visual sizing up. will get round to it this weekend, but its like the difference between a 5/10c piece and a 20c piece. if you have them both to compare the difference is clear.
still to confirm 100% that the other box isnt lsd, but id think it most likely is not.
flygt4
Postby TRD_ZERO » Fri Jan 26, 2007 3:06 pm
Ill give mine a measure but you can kinda see the difference in the photos posted that the one with the smaller hole diameter is the lsd one and the non lsd one had the larger hole.
TRD_ZERO
Postby crispy'86 » Sun Feb 04, 2007 8:43 am
had a look at my ae92 boxes and they both have the smaller hole about 10mm diameter, and when you look up close it seems you can see what appears to be a small bolt on the inside of the unit , guessing lsd's where the axle goes through the plate is about 10-15mm thick too. What i noticed when i looked up close at them
crispy'86
Postby Mr Revhead » Sun Feb 04, 2007 9:58 am
just a point...
a TRD plate type LSD will have a clear hole right through
the C series TRD helical LSD has a little plate in the axle holes so you cant see through it
Postby crispy'86 » Thu May 10, 2007 10:43 pm
I'm going to pull my gtz gearbox down very shortly so will be able to take pics step by step and take note especially where the axle goes through the splines, watch this space
crispy'86
