Changing Rev limit on 4AGE blue top.
Postby Caveman » Thu Feb 01, 2007 4:43 pm
Dont rely on maths and drivetrain calculations, etc
tp got my rpm all fuked up, apparently I redline below 7000rpm (around 6800) with a 4age. big load of crap.
only true way to tell is to hook up the dyno and the -ign output.
AW11 Track Toy
Formerly known as 1998
Caveman
Postby big_boy » Thu Feb 01, 2007 6:35 pm
is it cut by a relay/transistor if so you could just bridge it out
for sale EE90
big_boy
Postby Stealer Of Souls » Fri Feb 02, 2007 8:37 am
Caveman wrote:Dont rely on maths and drivetrain calculations, etc
Interesting... Surely the dyno's road speed can't be wrong since isn't it measured from the rollers... i didn't go from the TP RPM readout. I went off their road speed.
My maths is good. All the comparisons I've done between my calculations and actual on road values lines up pretty darn close.
You can't really argue with fixed ratio calculations. As an engineer you should know that.
'86 AE85.5 Levin
Stealer Of Souls
Postby Caveman » Fri Feb 02, 2007 11:43 am
Yea sorry I didnt intend to put down your maths
the problem is you dont know for certain the accuracy of the dyno speed, tyre size, gear ratios, etc
eg a tyre diameter will change as speed increases. not by much but still introduces error
im just saying for a difinitive result, your -ign will provide a descrete and accurate result.
then work from there.
I think a speed sensor going into the ecu would help, as some cars lower the rpm limit while at idle
or run a megasquirt, and dont give me its too hard excuse, mr electrical engineer :P
AW11 Track Toy
Caveman
Postby Stealer Of Souls » Fri Feb 02, 2007 1:51 pm
Caveman wrote:Yea sorry I didnt intend to put down your maths
It's not too hard... I'm too lazy :P
At this stage I don't want to go through the process of any aftermarket ecus. Having done a bit of reading I've come to the conclusion that the factory ecu (for all it's limitations) is actually really good. I'm not outside it's boundaries yet, so for now I'll stick with it. And for the little changes I think I'd like to make I'll go for some of the interceptor type add ons.
I'll have to get back on the dyno again soon, and make sure the car is all warmed up and everything and see if it still seems to cut earlier than expected. I'll also chase up a speed sensor answer to eliminate that too.
'86 AE85.5 Levin
Stealer Of Souls
Postby matt dunn » Fri Feb 02, 2007 8:25 pm
did you allow for tyre slip if it was a rolling road dyno?
And the RPM limit is triggered buy the inputs from the dist into the brain of the ECU, and if you interupt them you will also interupt spark and therefore stop the car anyway.
There is no transistor or relay to bridge.
If there was an easy way of doint it there would be aftermarket RPM limit removal chips available buy some of the bigger companies that do chips.
Postby NZ_AE86 » Mon Feb 05, 2007 4:15 pm
Tyre size varies from one brand to another so working speeds out from that is a waste of time!
Current rides;
1985 AE86 Race/Rally Car
1986 Levin GT
NZ_AE86
Postby matt dunn » Mon Feb 05, 2007 9:01 pm
NZ_AE86 wrote:Tyre size varies from one brand to another so working speeds out from that is a waste of time!
yip, agree totally.
Postby dash » Fri Feb 09, 2007 7:02 am
On our nissan s13 forum, a 'crystal' was swapped in the ecu to raise the rev limit. Apparently they guy knew about ecus and how to calculate it. Experiment worked.
dunno if toyota ecu has one
dash
Postby matt dunn » Fri Feb 09, 2007 10:17 pm
dash wrote:On our nissan s13 forum, a 'crystal' was swapped in the ecu to raise the rev limit. Apparently they guy knew about ecus and how to calculate it. Experiment worked.
Nissan, Subaru, Mitsi, all can be chipped one way or another and it is very common to do so.
Toyota's however, cannot be chipped.
Postby dash » Sat Feb 10, 2007 2:09 pm
I'm referring to a 'crystal', not the eprom.
Here, check out this thread;
http://forums.freshalloy.com/showthread ... cu+crystal
On 'chipping' the ecu...
A handful of people (mostly europeans) have claimed to custom reprogram toyota 4age ecu - several posted on club4ag.
I can only recall one u.s. outfit that does so as well.
I dunno what the process involves tho, so it may be quite different from nissan, mitsu, etc.
dash
Postby Mr Revhead » Sat Feb 10, 2007 4:11 pm
google a guy called peter brock
see his results on cyrstals in cars
