Caldina GT-T modifying
Postby gttNICK » Mon Apr 09, 2007 5:51 pm
slighty_sykotic wrote:What car was it?
Not being a dick now.
Really am interested... I find that pretty hard to believe.
It was a mk2 VW Golf
If you search the forums on VASK.org.nz you may be able to find it
Caldina gt-t
gttNICK
Postby solitaire » Mon Apr 09, 2007 6:09 pm
i owned a mkii golf 1.6litre and they wernt exactly cutting edge tech, great little cars but they had a similiar feel to a ae82 technology wise.
I reckon you could get respectable gains replacing the pod filter on a mkii, but i doubt the performance toyotas of the 90's would suffer the same bottleneck.
AE92, KZJ120, KDJ120
solitaire
Postby fivebob » Mon Apr 09, 2007 6:10 pm
lol, if you haven't noticed this thread is about a late 90's Turbo charged Toyota not an 80's NA VW Golf, which had a very poor performing engine to start with.
I never said a pod filter doesn't a make a difference on some cars, just that a pod filter produces no detectable power increase, on a Caldina GT-T
Postby Dell'Orto » Mon Apr 09, 2007 7:05 pm
fivebob wrote:FWIW a pod filter produces no detectable power increase, according to my Blitz Power Meter
Not saying that you're wrong, but I've seen some very interesting/wildly wrong results from the Power Meters before.
Postby fivebob » Mon Apr 09, 2007 7:16 pm
If you use them as a tool to get accurate power readings then maybe they might be out by a few Kw, but no more than the difference between two dynos. However if properly used they provide a very accurate way of determining changes in power produced. After all, they use the same principle as a rolling road dyno to get the readings.
If you do silly things like use them on a downhill(or uphill) run, in the wet, or switch it on when the vehicle is moving, then you can get very innaccurate results.
However if you use them in the way I do, which is doing several runs in both directions over a flat section of road (well it's flat according to the council engineers) and then averaging all runs, which in this case are within a couple of HP. then it's a very useful tool.
Postby Santa'sBoostinSleigh » Mon Apr 09, 2007 10:05 pm
AJz wrote:THIS is how i have mine set up.
(note: the air temp sensor is still hanging in its original position, i plan to move this)
(correct me if im wrong) if you run the air temp sensor in the engine bay, its probably going to mess around with what the ecu sees the temp as vs what temp is actually going into the motor and therefore muck up the fueling/timing??
My BOV is basically done the same way
however that was an old photo and its changed a bit since then
i run a K&N panel in the stock airbox and it seems fine
fivebob - have you got any pics of your extra air ducting? i wouldn't mind installing some myself at some stage
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby Burning Angel » Tue Apr 10, 2007 12:01 am
the air temp sens on the caldina gtt only measures air temp before the turbo(well the one were talking about) and as far as i know thats only for emissions purposes. the turbo is going to heat this air and also there will be variances in temp due to heatsoak in the interwarmer. these are picked up by this temp sensor here
(pic thanks to fivebob)
the airbox sens prob only effects the performance in fuel consumption
my take on the whole gtt modifying thing from what ive seen on this forum and from personal experince is as follows.
*The engines are pretty good in stock form(260hp)
*pods dont do much but can improve higher rpm breathing in cold ambient temps(butt dyno)
*bovs go vrrrmm-psssht(thats all)
*guttting the cat seems to improve turbo response(eye to boost gauge dyno)
*boost increase: dont use a bleed valve or the like(on any car prone to spikng) use a decent ebc and dont exeed 15 pound in stock form.
* to go any higher you will likely need extra cooling(oil) and an ecu upgrade (and by ecu i mean soming like a linkplus or motec not a piggyback. power fc may be acceptable in some cases)
and you might say $2000 plus is alot of money to spend but the gains in performance are not just the peak figures everone likes to quote.
when tuned by a competent tuner an aftermarket ecu can extract more torque(and a broader spread) more throttle response, more driveability AND more peak power from even a stock engine.
this then leaves you in the position for injector upgrades, turbo, intercooler, cams and much more and not need to worry that the engine may be destroyed by incorect parameters.
Burning Angel
Postby fivebob » Tue Apr 10, 2007 2:27 am
Santa'sBoostinSleigh wrote:fivebob - have you got any pics of your extra air ducting? i wouldn't mind installing some myself at some stage
Nope, got no pics of that. It was added after that pic was taken. and it's all hidden anyway. Besides which it wouldn't be of much use unless you have the TRD front end, and remove the standard airbox resonator.
Postby gttNICK » Tue Apr 10, 2007 1:24 pm
[/quote]
[/quote]
Yes I did notice but since everyone was adding their 2cents on POD filters I thought I would add mine.
And the engine in the Mk2 Gti golf was a great performer, way ahead of their time. But yes it is not a 2L turbo, although I thought an engine like this would only amplify the effects...
Caldina gt-t
gttNICK
Postby solitaire » Tue Apr 10, 2007 3:43 pm
gttNICK wrote:And the engine in the Mk2 Gti golf was a great performer, way ahead of their time. But yes it is not a 2L turbo, although I thought an engine like this would only amplify the effects...
In what way? They where reliable but i would not call them ahead of their time...
solitaire
Postby AJz » Tue Apr 10, 2007 4:16 pm
enough with the flaming :roll:
I had vtax :(
AJz
Postby solitaire » Tue Apr 10, 2007 4:18 pm
Im not flaming, we are comparing engines, ive made no personal attacks whatsoever.
solitaire
Postby Mr Revhead » Tue Apr 10, 2007 4:28 pm
i cant see any flaming
but i can see some offtopic.....
so lets stick to the topic please :D
Postby solitaire » Tue Apr 10, 2007 5:31 pm
Mr Revhead wrote:but i can see some offtopic.....
Fair enough - Cant argue with that :D
I think the post author has had his questions answered,
solitaire
Postby gleem » Tue Apr 10, 2007 9:58 pm
blunt question here exhaust off the turbo 3" or 2.5"?
gleem
Postby solitaire » Tue Apr 10, 2007 10:45 pm
http://www.aussie-speed.com/faq.htm
Read the first faq, in my opinion 3" is futureproof for you... but im not a techie...
solitaire
Postby Santa'sBoostinSleigh » Tue Apr 10, 2007 10:52 pm
im in need of a new rear muff actually, mines got holes like a damn sieve
any opinions/ideas on brand/price etc etc?
i *think* my current system is 2.5" but will need to check
and no i dont want a rice cannon :p
Santa's Mega Sale
Postby Chickenman » Tue Apr 10, 2007 11:12 pm
I've heard these sound really nice.
Baby Jesus
Chickenman
I Am The Walrus!
Postby Santa'sBoostinSleigh » Tue Apr 10, 2007 11:22 pm
milo ftw
Santa's Mega Sale
Postby AJz » Wed Apr 11, 2007 12:58 am
gleem wrote:blunt question here exhaust off the turbo 3" or 2.5"?
if you mean which is goin to be better in this situation id say you dont need more than a 2.5, some people will disagree with that though.
As for santa, ive got a sports muffler on the end and it sounds nice, just a low rumble but not annoying. Not sure of the brand, was from Magoo Mufflers.
I had vtax :(
AJz
