4agze goes chuff??
Postby matt dunn » Mon Aug 13, 2007 9:00 pm
pyro_sniper2002 wrote:I had a friend with an AE101 Marino 20V, that stuffed the ecu. Does exactly as you discribe. Its most likley to old to work with a scan tool. My MR2 doesnt work with the old mans Snap on one. And the MAP should be on the firewall and called vacume array sensor or manifold pressue assembly possibly.
Should work 100% with a scan tool,
Fault codes and live data.
Map sensor will be labelled turbocharger pressure sensor probably.
Could be a faulty ECU, but that normally only happens with the 20V's not the GZE's, but anything is possible.
Postby Crucible » Mon Aug 13, 2007 9:03 pm
you do have the map sensor hooked up on the engine side of the TB right? not to your new AFilter pipe!
Map sensor is located by the coil packs and pass side of the intercooler.
Also make sure that Pod filter hasnt lost the little centre cap and sucked it into the top of the housing, they are cronic for that, Ive come across that on a 4agze, wouldnt rev past 3k. Cost him like 2.5k worth of sparky and mechanic bills before I found the problem :wink:
Crucible
Real Life Mechanic
Postby pjay » Mon Aug 13, 2007 9:06 pm
Is it there ??? :?
pjay
Postby Crucible » Mon Aug 13, 2007 9:12 pm
True-No-Turbo wrote: Map sensor is located by the coil packs and pass side of the intercooler.
its a small black box with a single small vac hose, under the cooler pass side. The vacuum hose taps in by No1 intake runner from memory.
Crucible
Real Life Mechanic
Postby pjay » Mon Aug 13, 2007 9:14 pm
where..... :? sorry im not too familiar with proper terms
pjay
Postby Crucible » Mon Aug 13, 2007 9:27 pm
at the back of the rocker covers, under the intercooler, around the coil pack area where the h/t leads are. If you were to stand infront of your car lean over and hold yourself up with both hands either side of the intercooler, it would be round about where your centre finger rhand is...
if you dont get that...well... you need a kick in the $#@! :D
Crucible
Real Life Mechanic
Postby pjay » Mon Aug 13, 2007 9:30 pm
Lol!!!! cheers mate! Well i grounded T1 at the ECU itself and NOTHING. sweet f-all self diagnosis. ill check the map sensor now
Im starting to think perhaps i did short something in the ECU. oh well...on the bright side, needed a tune up after that airbox was put in anyway :)
pjay
Postby XSVWGN » Mon Aug 13, 2007 9:37 pm
My ZE did this about a year ago. Mine was AFM but i had a air leak under the throttle body and the charger relay was $&#$%
2008 Kia rio - work car
XSVWGN
Postby pjay » Mon Aug 13, 2007 9:48 pm
well the map sensor looks fine. ill just pop my ecu out and take it around to shendian to comb over..
At the least, it will eliminate the computer from the equation
pjay
Postby Crucible » Mon Aug 13, 2007 9:51 pm
pjay wrote:well the map sensor looks fine.
what about the vacuum supply?did you check that??
Crucible
Real Life Mechanic
Postby pjay » Mon Aug 13, 2007 9:55 pm
i believe so. all vacuum lines are connected...wait.. give me a minute. ill check for blockages. never thought of that
pjay
Postby Crucible » Mon Aug 13, 2007 10:07 pm
Id check for vac at the sensor itself with a gauge just incase you mixed the hoses up? just be careful not to break the map sensor when your pulling the hose off, they are pretty fragile.
if that checks out ok, it elimanates that from the equation.
Crucible
Real Life Mechanic
Postby pjay » Mon Aug 13, 2007 10:07 pm
vacuum lines are sweet. its prolly the ecu.. anyone have a sweet ecu i can chuck in to confirm mine faulty :lol: :roll:
pjay
Postby pjay » Mon Aug 13, 2007 10:11 pm
True-No-Turbo wrote:Id check for vac at the sensor itself with a gauge just incase you mixed the hoses up? just be careful not to break the map sensor when your pulling the hose off, they are pretty fragile.
i dont have any gauges :s
pjay
Postby themaleman » Tue Aug 14, 2007 9:07 am
[/img]Image
that should be the vacume line 2 the map sensor, follow it and check for splits ect
[img][img]http://img159.imageshack.us/img159/3789/image598lb3.th.jpg[/img]
thats the map sensor on a ae92 gtz[/img]
manual 80 series cruiser
4agte ae92 Levin
a15 powered sj410
themaleman
Postby pjay » Tue Aug 14, 2007 9:41 pm
Ok my ECU is in at shendians down by torque performance getting diagnosed. will have the news tomorrow.. fingers crossed it is the ECU that has the problem!
pjay
Postby Dell'Orto » Tue Aug 14, 2007 10:22 pm
Shen Dian do auto electrical stuff???? 8O
Postby pjay » Wed Aug 15, 2007 9:30 am
Mmm, Boost wrote:Shen Dian do auto electrical stuff???? 8O
Guy there called Jason. HE is a GURU with ecu's.. recommended by joes mechanical and some other mates with high boosting crx's and shit
pjay
Postby matt dunn » Wed Aug 15, 2007 8:22 pm
We have had mechanical warranty companies make us send ECU's to them for repairs before too I think.
Postby pjay » Wed Aug 15, 2007 8:30 pm
Well the car is FIXED!!
was the ECU. just age, and short circuits :)
Jason at shen dian is awesome. as is Joe at joes mechanical. i highly recommend them.. hands down!!
Woooohoooo. BOOOOOST is back
pjay
Users browsing this forum: No registered users and 34 guests
