Exedy clutch problems
Postby Bazda » Thu Dec 02, 2010 4:51 pm
shihad wrote:
Bazda wrote:meh get a twin plate :D
viewtopic.php?t=81763
LOl he doesn't have 4age thread confusion my bad.
I wouldn't touch that clutch. They are VERY hard to drive with. Its really like an On/OFF switch with those units.
Its an old design and the clutch plates dont last that long.
Postby Adamal » Thu Dec 02, 2010 6:01 pm
THA SHZ wrote:
allencr wrote:If it was the bearing retainer tube that is too long & has been keeping it slightly disengaged, I think that the PP's fingers would have been pretty chewed up & nasty looking the first time you removed it. Were they?
also depends how long ago they welded it and whether they machined the bearing down to suit or not , our last option is to machine the snout , very last option .
Found the part and its on the way :)
Postby allencr » Fri Dec 03, 2010 8:17 pm
So was it a parts-mis-match on a swap, or the Exedy clutch design has too small a hole for the stock tube that will need to be shortened?
I'd leave about 10-15mm at least between the fingers & tube for wear.
Any chance it'll ride off the end & jam?
allencr
Users browsing this forum: Bing [Bot], Google [Bot] and 17 guests
