4AGZE Lightend Fly Wheel
Postby Monsterbishi » Wed Sep 08, 2004 11:49 pm
Al wrote:
Bazda wrote:So how much power am i making?
At a rough guess, around 170-175fwkw
Basically you look at other peoples 1/4 times and their trap speeds, compare weight with your car etc, its an educated guess.
I wouldn't say it's anywhere near that, a 1600cc motor, with 15psi through a t3 compressor wouldn't make 230-240fwhp.
--- Cut Here ---
'94 JDM Ford Mustang GT Coupe
Monsterbishi
Postby Bazda » Thu Sep 09, 2004 9:47 am
thats around what i think i have also.
my old man used to drag race a dair bit back in his day and a lighter flywheel did make a difference he said. Back in late 1970s and early 1980s a 13.1s in a street ford escort mk2 (2L turbo) was pretty impressive in those days.
Postby EVLGTZ » Thu Sep 09, 2004 10:00 am
compare to my 13.85 @ 170km with only 131kw @ wheels
EVLGTZ
Ex 4AGZE AE82 - 14.2@163km/hr
EVLGTZ
Postby 4AGTE » Thu Sep 09, 2004 10:11 am
ok just found my slip things and my best speed over the line was 166kph.
4AGTE
Postby Bazda » Thu Sep 09, 2004 1:55 pm
EVLGTZ wrote:compare to my 13.85 @ 170km with only 131kw @ wheels
what about your recent run...
to be honest I have no idea what kws i have.
at shore performace ages ago when i was running 12psi, exhaust housing far to small, no external, no bluetop cams and running like poo i got 130kws, and shore performances dyno reads alot lower than torque performance.
Postby EVLGTZ » Thu Sep 09, 2004 2:15 pm
hard to say with recents runs due to those conditions and the varying boost levels I ran. There was a 14.005 @ about 172-173km on 14psi. I'd figure at that amount of boost I may have 155-160kw at a guess???
EVLGTZ
EVLGTZ
Postby Bazda » Thu Sep 09, 2004 8:52 pm
well i must have about that kinda kws when i did my 13.5.......
one of my runs i did a 0-60ft of 2.8s and final of 14.5@172, that was on 16psi.
my 13.5@174(108mph) run was on 15psi but i got off the line alot better.
seems like any 4agte gets up to a certain speed good, and to go any faster u needs lots more hp!!
even takusumi (cant remember his name) did a 12.5@109mph...
Postby Al » Fri Sep 10, 2004 1:00 am
yes but tukumis car drives the proper wheels, you boys can only dream of rwd traction :lol:
plus he launches on the limiter in 2nd gear with khumo v700s 8)
Al
Postby jondee86 » Fri Sep 10, 2004 9:37 pm
Here is a pic of the flywheel on my 16 valve small port.
You can see the drill marks at the top where it was
dynamically balanced with the pressure plate. Engine
hasn't been run yet, but I expect it to be pretty responsive :)
Cheers....
jondee86
Watch this space >>> <<<
jondee86
Users browsing this forum: No registered users and 30 guests
