200kw out of a black top
Postby Crampy » Fri Nov 28, 2008 4:28 am
Cool, I want one.
Crampy
Postby IH8TEC » Fri Nov 28, 2008 9:15 am
sounds expensive to me :? when you look at the price of a decent turbo these days that are proven.
maybe its just me, still a cool idea though
Postby xsspeed » Fri Nov 28, 2008 9:24 am
Does sound pricey, but I guess it depends how refined you make your product at how much R&D and testing you do. Wicked idea though, keep us posted with details.
BTW I have a Holden Premier that will be in the works soon gunna put an LS1 or LS2 into it, would love to have a procharger hanging off the side, so quick build them and test them, then make them big enough for v8's! :lol:
Postby cedwards » Fri Nov 28, 2008 12:46 pm
Nice work, how you gonna mount it? There seems a fair bit of leverage with the gear box housing length to your drive pulley?
cedwards
Postby tsoob » Sat Nov 29, 2008 10:54 am
+1 for barrys engine, save you a whole lot of hassle later when you decide 150kw isin't enuf
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby tim_blair » Sat Nov 29, 2008 7:57 pm
well i geuss i had better start thinking about making some more
as far as price goes it depends on how much i can get the parts for and and how long all the machining takes it could even be as cheap as 600?
but look at it this way if you were to turbo you would need
turbo 500-800 depending on size, age, brand etc
manifold 300-500
wastegate 200-400
dump pipe 50-100
exhaust 100-300
gaskets 100
so you looking at 1250-1400 for a turbo set up
and if you go charger then you need
charger 700-1000
mounts 100
belt 40
840-1140 bit cheaper and no lag no extra heat to your oil or coolant and you have something different
however you do loose power to run it
and im not sure how much boost they would create
tim_blair
Postby tim_blair » Sat Nov 29, 2008 8:25 pm
my one will be mounted where the window cleaning fluid bottle is (ae111)
attached to the engine mount thats there and the pulley will sit close to where the powersteering pump is (which i am going to remove) and driven by the crank pulley that drives the powersteering and ac pumps
when you say there looks like a bit of leverage coz of the length of the gear casing your right but there is a bearing right next to the pulley the gears them selves are mounted firmly in the housing so i hope there is enough support to stop the input shaft flexing
tim_blair
Postby Crucible » Mon Dec 01, 2008 10:08 pm
~SlideWays~ wrote:
True-No-Turbo wrote:yeah would have to be a fair bit more than 200kw to break traction in 3rd, I could get my trueno to let go when cornering if i kicked the clutch in dry but theres no way itll spin through 3rd from 2nd or spin in 3rd when coming on boost.
in the wet is a differant story though
Don't forget the gear ratio differences, the gtz box's have looooooooooooong gears so would be much harder to spin 3rd vs's the close ratio and shorter gears of a b18c gbox .
Yeah thats a good point! 8)
Crucible
Real Life Mechanic
Postby IH8TEC » Mon Dec 01, 2008 10:16 pm
pfft, breaking traction in 3rd is easy 8)
Postby ~SlideWays~ » Tue Dec 02, 2008 9:29 am
IH8TEC wrote:pfft, breaking traction in 3rd is easy 8)
So's your mum!
lol...couldn't resist
PS will be interesting to see how much compression increase effects your new engine 8)
~SlideWays~
Postby deanis » Wed Dec 10, 2008 1:03 pm
home made parts are rad.
flag the turbo setup and get this supercharger running!!
12.7@174kph. no turbo, no supercharger, no NOS, ALLMOTOR.
deanis
Postby Crampy » Wed Dec 10, 2008 2:34 pm
deanis wrote:home made parts are rad.
Spoken like a true Ginge (Actually it should have been in orange writing)
Supercharger does look really cool though. I'm interested in seeing the results.
Crampy
Postby tim_blair » Wed Dec 10, 2008 6:06 pm
yea im geussing ill have it on the car in maybe 2 months
i will certainly keep every1 up to date with how its going
tim_blair
Postby tsoob » Wed Dec 10, 2008 10:07 pm
RECKON
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
