thanks
Matt wrote:Just out of interest, I've seen a couple of FxGTV's around, what makes them different to an FxGT?
All_Fours wrote:kelford camtech in chch does a set of cams + adjustable pulleys for about $700, which are supposed to work on stock ECU and give around 20% hp increase. I'd definately take that route if I was modding an NA engine, it's not that hard to install cams, and degreeing and shimming isn't that bad either, just a bit tedious when there's 16 valves to shim.
low_rider wrote:BRING BACK COMMUNAL SHOWERS!!!!!!!!!!!!!
low_rider wrote:All_Fours wrote:kelford camtech in chch does a set of cams + adjustable pulleys for about $700, which are supposed to work on stock ECU and give around 20% hp increase. I'd definately take that route if I was modding an NA engine, it's not that hard to install cams, and degreeing and shimming isn't that bad either, just a bit tedious when there's 16 valves to shim.
is this true?
a 20% percent horsepower increase is HUGE for just cams isnt it
