Stock 20 valve cam specs?
Postby 10k 20v » Fri Mar 19, 2004 5:16 pm
Can anyone on here tell me the stock cam spec for a ae101 silvertop.
What i'm after is stuff like, duration, lift and lobe centres.
10k 20v
1
Postby PRYMORTAL » Fri Mar 19, 2004 5:26 pm
i found that stuff doing a search in google and yahoo, had to use Babblefish to translate the web pages (japanese), should try that but i'll see if i can find them again
PRYMORTAL
Postby AceSniper » Sat Mar 20, 2004 4:43 pm
yea iv also seen the spec's on the net dont have time atm... but searching for "4age specs" brought it up somewere I think
AceSniper
Postby mister2 » Mon Mar 22, 2004 10:46 am
bill sherwoods site has em.
from memory (like all info on the net... imho!) intake 250* 8.0mm lift inlet opens 0* closes 70* abdc (vvt: opens 30*btdc closes 40* abdc) exhaust 250* 7.6mm lift opens 54* bbdc closes 16* atdc.
check to be sure.
nick
www.nzefi.com
4WD Dynapack Dynamometer.
Link, MoTeC, Greddy, Power FC sales support and tuning.
Weapon of Choice: 1992 NSR250 SE
On hiatus, current location: Cambridge, UK
mister2
Postby 10k 20v » Mon Mar 22, 2004 6:46 pm
Cheers guy's, i lost my standard exhaust cam wheel and was trying to dial it in without sucsess. Hence the need to know.
10k 20v
Re: Stock 20 valve cam specs?
Postby matt dunn » Fri Apr 30, 2004 7:17 pm
10k 20v wrote:Can anyone on here tell me the stock cam spec for a ae101 silvertop.
And also after std valve clearances for AE101 silvertop
