help!! i can't get the k50 out of the ae85!? :-(
Postby (((***Paul***)))ae85 » Thu Apr 08, 2004 11:55 pm
please help the novice trying to learn :-)
i have got everything unbolted, the gearbox is free but the gearnob stops it going far enough back to drop out... i was told i should be able to get the k50 out without removing the gearnob... and the oil.
so, am i surposed to unbolt some of the clutch setup? (sorry don't know all the names of the parts) its like the spline is being stopped by it.
thanks
paul
Re: help!! i can't get the k50 out of the ae85!? :-(
Postby matt dunn » Fri Apr 09, 2004 12:20 am
(((***Paul***)))ae85 wrote:please help the novice trying to learn :-)
thanks
paul
Dont know who told you what but all the rwd toyota boxes i've taken out you have had to remove the gearlever to get it to come back far enough to get it out and if you dont drain the oil it will leak out the driveshaft hole if you tip it that way.
Postby gmacrae » Fri Apr 09, 2004 12:54 am
you say you have the gearbox unbolted, have you unbolted the bellhousing from the block of the gearbox from the belhousing? coz you wont be able to pull the gearbox away from the bellhousing, just in case that's what you were trying to do... i know this from fiist hand experience lol :oops:
gmacrae
Postby PumpN » Fri Apr 09, 2004 5:51 pm
you need to remove the gear knob and lever, this is a one minute job, the whole thing is held in place by a circlip (dont loose it), just get a circlip tool or some needle nose pliers to take it out and then you can pull the lever from the box from in the cabin (dont loose the circlip, i mean it)
as for the oil, unbolt the driveshaft flange at the diff (of its a one piece driveshaft) and pop it down, do not pull the driveshaft out the back of the box other wise it will dump it oil, just leave it hanging
get a mate aswell, i have done this before about 3-4 times now, and it is a two person job if your doing it at home without hoists and other hydrolic goodies
'92 Nissan 200SX, Need a Daily driver!!!
PumpN
Postby (((***Paul***)))ae85 » Sat Apr 10, 2004 5:58 pm
Thanks heaps for all ur help. I took the gear stick off and it came out easily. :D
