4WS light on in Celica
Postby Swampy » Fri Apr 16, 2004 6:12 pm
The 4WS light comes on in my celica after about 5 mins of driving. :(
Does anyone know what I can check or look for. I`ve tried the " sport/normal switch and 2WD/ Reverse switch, which makes no difference. Not sure how its spose to work but with light is out the rear wheels turn the opposite to the front. Now when the 4WS light stays on ,then the rear wheels turn the same way as the front....make sense??
Is there anyone out there that can shed some light on this for me please..
Cheers.....
Have a happy day
Swampy
Postby Swampy » Sat Apr 17, 2004 9:22 am
Can anyone tell me where the Speed sensor is in a ST183 ??
Have a happy day
Swampy
Postby Mr Revhead » Sat Apr 17, 2004 10:51 am
common on the 4ws sillycars is for the motors for the rear steering rack to crap out. take your car to a TOYOTA dealership as they will most likely be familiar with the problem therefore making an accurate diagnosis quiker
Postby celica_tommo » Sat Apr 17, 2004 7:21 pm
its not on the driveshaft so i assume its on the hub somewhere
celica_tommo
Postby BlakJak » Sat Apr 17, 2004 9:38 pm
Speed sensor is on the front left wheel, you'll recognise it as connected to the 'extra' cable that isnt present on the right hand side.
Theyre about $350 odd from Giltrap City Toyota (and impossible to source second hand)
I did the one in my 183 about 2 years ago.
BlakJak
Postby Swampy » Sun Apr 18, 2004 10:07 am
there are no wires at all on the front wheels. I thought it would be up near the speedo somewhere. What about the 4WS ECU,any thoughts on where that would be??
Have a happy day
Swampy
Postby Swampy » Sun Apr 18, 2004 10:25 am
Found the plug up in the inner guard and where its spose to be in the hub. Its been broken off at the hub. Its a bitch tring to get the metal bit out of the hub tho. CRC will do the trick I hope. Anyway thanks for the info.
Cheers..........
Have a happy day
Swampy
Postby celica_tommo » Sun Apr 18, 2004 12:38 pm
so was it your speed sensor that was making your 4WS not work?
celica_tommo
Postby Swampy » Sun Apr 18, 2004 6:32 pm
ill get a new one and plug it in then we will see. knowing my luck there will be another fault with it somewhere....
Have a happy day
Swampy
Postby Mr Revhead » Mon Apr 19, 2004 9:22 am
email me ya model and frame numbers and ill do ya a deal on a new one
