Is this bad (using oil) in 4agze
Postby Volatile » Sun Apr 18, 2004 7:15 pm
Hey, i just went to check out the ae92 gtz i'm hoping to get
the guy says it between oil changes 5000km, the car normally requires half a litre top up.
is this bad?
James
Volatile
Postby Volatile » Sun Apr 18, 2004 7:31 pm
also, does anyone know what the compression should be on a
1990 Map sensored 4agze?
James
Volatile
Postby Bling » Sun Apr 18, 2004 7:57 pm
my blacktop used oil at first, i think i got 30w15 or something put in it, but have since changed to a "thicker" oil and it doesn't budge now on the dipstick, so all good. So it could be the oil he uses, just an idea :)
Postby gtz666 » Sun Apr 18, 2004 8:48 pm
hmm my ae92 ze uses bout that amount for top up between service use magnatec but i do have 194000 on the clock and frequently hit limiter :twisted:
gtz666
Postby PumpN » Sun Apr 18, 2004 11:02 pm
for that amount of kays its not a problem, old saying is it needs a rebuild if it uses more than a litre every 5000, but as said above 4ages tend to use a bit of oil if its too thin
my mazda however did use oil, something like 16 litres in 3000 kays 8)
'92 Nissan 200SX, Need a Daily driver!!!
PumpN
Postby AE85.6 » Sun Apr 18, 2004 11:07 pm
dude thats alot of oil 8O must have looked like a crop dusting plane with the smoke that must have been cranking
If you drink, and drift,
your a bloody lunatic
AE85.6
Postby Lloyd » Sun Apr 18, 2004 11:16 pm
Compression should be around 8.9:1 for the post-mid-89 models I think
Postby Volatile » Mon Apr 19, 2004 8:29 am
TTT
anyone else??
Volatile
Postby Lanius » Mon Apr 19, 2004 8:45 am
Yeh ... my '89 GZE goes through a lot of oil.
You might also wanna get the s/charger oil checked out eh. Sucks to get a GTZ with a dying supercharger.
Lanius
k
Postby 93Levin4AGZE » Mon Apr 19, 2004 9:09 am
if u dont want to happen like my ae101 gtz, chek oil frequently and fill up frequently.
there's nothing else u can do for ur AE92 becos they r old and the oils do burn quite alot.
and whenu miss that the oils have run out, say bye to ur engine~
if the engine oil gets burnt too quickly(heaps od somke out of ur exhaust), check ur pistons and rings!
other wise rebuild them!
read what happen to mine!
well, i was stupid...but dont want to c this happen to other people aye..
93Levin4AGZE
Postby Volatile » Mon Apr 19, 2004 3:49 pm
what are sign's of a dying s/charger?
James
Volatile
Postby Banga69 » Mon Apr 19, 2004 4:38 pm
Volatile wrote:what are sign's of a dying s/charger?
James
oil leaking, whinning sound, umm blows up
CURRENT:
1994 Mazda Lantis
EX:
SOLD: AE101 GTZ ====>http://toyspeed.blakjak.net/profiles/profile.php?id=89
Banga69
Re: Is this bad (using oil) in 4agze
Postby Twolitre » Mon Apr 19, 2004 5:57 pm
Volatile wrote:Hey, i just went to check out the ae92 gtz i'm hoping to get
is this bad?
No it's not bad and the fact he was being honest with you is good, any old person can say "nah it's sweet, doesn't use any oil bro" also oil changes every 5000Km's is a good sign
Pull out the dipstick and see if it looks clean, also look under the oil cap for sludge, if it's been serviced properly the coolant will also be bright green.
Twolitre
Postby PumpN » Mon Apr 19, 2004 6:00 pm
Twolitre wrote: if it's been serviced properly the coolant will also be bright green.
or transparent red colour if toyota genuine or most newer brands of long life coolant has been used, which is an even better sign, if its an orange rusty colour then its definitely not a good sign
PumpN
oil
Postby AE101Z » Tue Apr 20, 2004 1:33 am
20V eat oil, my friend has changed a trd head gasket for a week (of course change oil as well) and went to puke, and his engine fxxk up when he was on the way home and the black top ate all the engine oil in a week......
AE101Z
Postby Lanius » Tue Apr 20, 2004 7:51 am
There was something seriously wrong if it ate all that oil in a week.
Lanius
Postby Volatile » Tue Apr 20, 2004 4:03 pm
bump
Volatile
Users browsing this forum: Bing [Bot] and 74 guests
