fuzzylogic wrote:yeah, the thing is the voltmeter on my car reads below 14v. its about 12v even when the engine is running. i'm aware that it should read about 14 while running so i just wanna confirm that it is the alternator that needs replacing... how much will it cost to get it done?
jondee86 wrote:Hiya.... if the alternator is not charging, and you drive at night, you should notice the lights getting dimmer and dimmer, and the battery warning light should be on. Eventually, there won't be enough voltage to run the electrics and the car will just slow down and die![]()
But if the lights are bright and all the electrics (indicators, wipers etc) are working normally, then it's a safe bet the alternator is charging. Cheers...
jondee86
Loudtoy wrote:
Now the reason i doubt it is your alternator is
one - no charge light isn't coming up
two - your car actually runs fine once it's started
three - if your alternator was stuffed you wouldn't get any reading above 6 or so volts while it was running, which wouldn't be for very long if your alternator wasn't keeping things going. Also the voltmeters on the cars aren't always 100% accurate just normally pretty close!
