silvertop,flatspot
silvertop,flatspot
Postby fxgt race » Sat Apr 24, 2004 3:55 pm
is it just this engine or do other people find when thrashing it and changing gear the revs drop into a flatspot.it is going to be dyno tuned again soon but just wondering if the link computer can iron this out,we couldn't get rid of this problem last time and it seems to have something to do with the vvt kicking in.
fxgt race
Postby AceSniper » Sun Apr 25, 2004 10:43 am
Rev it harder an higher :D
if the engine is under strain (high gear low speed blah blah) and you try and floor it... or vvt comes on it will make a flat spot, ether change the vvt control to rev bassed or just learn to drive around it.
AceSniper
Postby 10k 20v » Sun Apr 25, 2004 11:22 am
i had the same problem when i was running a stock motor, and i put it down to the delay on the vvt pulley, so i just wired it up to stay to rpm on the link.
Fixed it.
But now i don't run vvt,
10k 20v
vvt
Postby fxgt race » Sun Apr 25, 2004 11:43 am
on the dyno we tryed different revs to bring on the vvt but it has been set at revs to give best results,might try uping the rev cut to about 8400, as for trying to drive around the flatspot is a bit hard on a race track.
fxgt race
Postby 10k 20v » Mon Apr 26, 2004 8:44 pm
i know this is a little off topic but how much power did it make?
10k 20v
power
Postby fxgt race » Mon Apr 26, 2004 9:59 pm
it made 90kw at the wheels.the car is 1985 fxgt but still had the original fuel filter and a standard exhaust with red line filter socks,they have been replaced with a pipercross single filter and will get a new exhaust and fuel filter before it gets back on the dyno,so hopefully it should make good gains with the new mods.
fxgt race
Postby matt dunn » Wed Apr 28, 2004 12:58 am
10k 20v wrote:But now i don't run vvt,
Why is that?
My 20V turbo race motor has aftermarket cams but i'm unsure if to run the VVT or not.
The guy i bought the motor off doesn't have the info as he just paid an engine builder to to build it and it was a few years ago.
Postby 10k 20v » Wed Apr 28, 2004 6:55 pm
Thats because i'm running aftermarket cams and i've dialled them in to excact cam specs.
If your turbo motor has stock cams i'd leave the vvt on.
We got vvega's 20 v turbo to hall ass with stock cams
10k 20v
Postby matt dunn » Wed Apr 28, 2004 8:55 pm
10k 20v wrote:Thats because i'm running aftermarket cams and i've dialled them in to excact cam specs.
No they have fitted cams (from kelford's i think) but i do not have the specs. It still has the VVt pulley on the front but i dont know if it actually does anything. It doesnt seem to make a difference when you switch it on or off even at idle.
Postby 10k 20v » Thu Apr 29, 2004 7:53 pm
As you no doubt prob already know there should be a grind no. stamped on the cam somewhere, I would qoute that to kelfords and see if they could bring up the specs. If it was csl they do a grind for the vvt pulley
10k 20v
Postby matt dunn » Fri Apr 30, 2004 7:16 pm
10k 20v wrote:As you no doubt prob already know there should be a grind no. stamped on the cam somewhere, I would qoute that to kelfords and see if they could bring up the specs. If it was csl they do a grind for the vvt pulley
Have some more info.
Was actually a place in Palmerston north that ground the cams, but i do not know the name of them.
I now also need some specs to set the tappets to. I was told by the guy who built the engine that they should be set as per standard 20V silvertop, but he does not still have the specs. Any suggestions?
Matt
Postby Loudtoy » Fri Apr 30, 2004 8:07 pm
Matt
As far as i know there's only te one place in palmy that does cams (correct me if i'm wrong) and that place would be CSL Cams there phone number is 06 356 3700 if you want to ring them and find out??
TS Member sine 2001
Prado To tow stuff with
Rodeo to do work stuff in
Loudtoy
Postby 10k 20v » Sat May 01, 2004 7:41 pm
intake.24 mm and exh .44
10k 20v
