10k 20v wrote:But now i don't run vvt,
10k 20v wrote:Thats because i'm running aftermarket cams and i've dialled them in to excact cam specs.
If your turbo motor has stock cams i'd leave the vvt on.
We got vvega's 20 v turbo to hall ass with stock cams
10k 20v wrote:As you no doubt prob already know there should be a grind no. stamped on the cam somewhere, I would qoute that to kelfords and see if they could bring up the specs. If it was csl they do a grind for the vvt pulley
matt dunn wrote:10k 20v wrote:As you no doubt prob already know there should be a grind no. stamped on the cam somewhere, I would qoute that to kelfords and see if they could bring up the specs. If it was csl they do a grind for the vvt pulley
Have some more info.
Was actually a place in Palmerston north that ground the cams, but i do not know the name of them.
I now also need some specs to set the tappets to. I was told by the guy who built the engine that they should be set as per standard 20V silvertop, but he does not still have the specs. Any suggestions?
Matt
Users browsing this forum: No registered users and 49 guests
