the fallen303 wrote:hey just wondering, the ports on a tvis equiped engine, are they two runners, each the same size as one without tvis, or are both runners equal overall size to the one without tvis? probably didn't explain that right, but i'll see how it goes like that...
the fallen303 wrote:so tvis is only really an advantage in the lower rpm? and a hinderance in the high rpm?
gdsup wrote:seen dyno graphs on high ps turbo 4ag with and without t-vis, only difference is more tourque and power down low with no drop off up highso leave em on
the fallen303 wrote:so what about just fethering the throttle? you know, only giving it half throttle, till, say around 3500 - 4000 rpm? isn't that basically the same thing that tvis is doing anyway?
Drifter4ag wrote:TVIS is absolute bad boy ..
i have run turbo setup initally with TVIS ..then tried it without ..
both putting up similar numbers but TVIS wiht more torque from the get go
so now
i have TVIS back in as it is the badassness and flows ( kw for kw) better than not ..
oh and i removed the whole plate when i took it out.. shortening intake runner by 1inch but torque wouldnt be adversly affected by this
Karl_Skewes wrote:bill hasn't turbo'd a 4age.
I don't know if bill has even built a motor with 270 cams.
DON'T TRUST COMPUTER DYNO'S!
The only way is with proper REAL LIFE Dynos.
It's been tested already.
Keep it in.
Oh...... and a big turbo is going to flow a heap more then 270 cams.
jondee86 wrote:Remember that when a turbo engine is not making any boost (at lower rpm's) it behaves just like a N/A engine, and will benefit from the action of the TVIS system.
