tvis ports
tvis ports
Postby the fallen303 » Tue Apr 27, 2004 7:00 pm
hey just wondering, the ports on a tvis equiped engine, are they two runners, each the same size as one without tvis, or are both runners equal overall size to the one without tvis? probably didn't explain that right, but i'll see how it goes like that...
true house of JZ
Stay true to the origin
the fallen303
Re: tvis ports
Postby Monsterbishi » Tue Apr 27, 2004 7:35 pm
the fallen303 wrote:hey just wondering, the ports on a tvis equiped engine, are they two runners, each the same size as one without tvis, or are both runners equal overall size to the one without tvis? probably didn't explain that right, but i'll see how it goes like that...
So you're asking if the volume of the tvis runners are greater or less than non-tvis?
They're(TVIS) actually less, due to the additional metal being used to close each runner off.
--- Cut Here ---
'94 JDM Ford Mustang GT Coupe
Monsterbishi
Postby the fallen303 » Wed Apr 28, 2004 12:01 am
wondering if the volume of the two tvis runners when fully open is the same as the runners on a car that does not have tvis (one runner).
hope that clears it up a bit
i've just heard some people say that seen as there are two runners, that they are each the same size as a single runner from a non tvis car, so that would mean that when tvis is wide open, that it would be recieving double the air than a single runner would. problem with that being is that then it would basically be worse than the single as instead of as the engine revs more, and needs the more air, it's recieving twice as much as it should.
think that is a it confusing, but yeah, it's late, so meh...
true house of JZ
the fallen303
Postby Ae92typeX » Wed Apr 28, 2004 12:13 am
so, for example, you are comparing the runners off a tvis 4age and a non-tvis 4age? yea?
Ae92typeX
Postby the fallen303 » Wed Apr 28, 2004 12:21 am
pretty much, yeah
wondering if at full noise, if they flow the same amount of air or not
guess thats what it all boils down to :roll:
i know that tvis is good for low end power, as it restricts the amount of air going into the motor at WOT at low revs, but once the revs get up, it opens the second runner, so that it flows full amount of air. i'm wanting to know if that amount of air is the same as a normal intake without tvis.
true house of JZ
the fallen303
Postby Jools » Wed Apr 28, 2004 1:27 am
As I understand it, the TVIS acctually flow less when open because the butterflies still sit in the middle of the flow. Non-TVIS is meant to flow more.
90 Celica GTR Turbo
184kw @ 14psi at the front wheels (Now running 17psi watch this space for dyno :) )
"Owner of the fastest Celica GTR in NZ (Until proved otherwise ;) )"
www.Jools.tk
Jools
Postby the fallen303 » Wed Apr 28, 2004 9:41 pm
so tvis is only really an advantage in the lower rpm? and a hinderance in the high rpm?
true house of JZ
the fallen303
Postby Twolitre » Wed Apr 28, 2004 10:11 pm
the fallen303 wrote:so tvis is only really an advantage in the lower rpm? and a hinderance in the high rpm?
Only on a modified engine running a turbo uprade with more boost.
The T-VIS butterflies when open are horizontal to that of the airflow so not that restrictive, but yes supposed to improve low down torque.
Twolitre
Postby gdsup » Wed Apr 28, 2004 10:36 pm
seen dyno graphs on high ps turbo 4ag with and without t-vis, only difference is more tourque and power down low with no drop off up high :) so leave em on
gdsup
Postby Twolitre » Wed Apr 28, 2004 10:42 pm
gdsup wrote:seen dyno graphs on high ps turbo 4ag with and without t-vis, only difference is more tourque and power down low with no drop off up high :) so leave em on
Is that with the T-VIS just disabled or the butterflies physically removed from the TVIS plate with the rods removed and port matched to the intake ports?
I agree that if you still have the butterflies you may as well use them otherwise you will not get any gains up top unless you remove them like I described above.
Twolitre
Postby the fallen303 » Wed Apr 28, 2004 11:07 pm
so what about just fethering the throttle? you know, only giving it half throttle, till, say around 3500 - 4000 rpm? isn't that basically the same thing that tvis is doing anyway?
true house of JZ
the fallen303
Postby Twolitre » Wed Apr 28, 2004 11:16 pm
the fallen303 wrote:so what about just fethering the throttle? you know, only giving it half throttle, till, say around 3500 - 4000 rpm? isn't that basically the same thing that tvis is doing anyway?
Not if you want maximum accelleration, T-VIS is designed to increase air speed post throttle body between plenum - intake port, many other manufactures use a variation of the same thing.
Twolitre
Postby Drifter4ag » Thu Apr 29, 2004 1:25 pm
TVIS is absolute bad boy ..
i have run turbo setup initally with TVIS ..then tried it without ..
both putting up similar numbers but TVIS wiht more torque from the get go
so now
i have TVIS back in as it is the badassness and flows ( kw for kw) better than not ..
oh and i removed the whole plate when i took it out.. shortening intake runner by 1inch but torque wouldnt be adversly affected by this
Garage |-" '|
Current Rides
AE86 Notchy (Finally through compliance after 5 years)
Vitz RS :D
Previous,
1x SXE10 Altezza, 2xAE111 Caribs, 3xKP60, 2xke35 SR Coupes, 2xAE85s, 2xAE86 Road Car, 1xAE86 Drift Car 182kw@wheels, 1xJZZ30 Drift Car 360ps
Panspeed Special 450ps Drift Car
JZX91 MARK II CHASER
JZX81 MARK II CHASER..... so many more that i forgot....
Drifter4ag
tvis ports
Postby jondee86 » Thu Apr 29, 2004 8:38 pm
The TVIS 16 valve 4A-GE head is known as the "big port" head, and the later non-TVIS 16 valve head is known as the "small port" head. The reason being that the intake ports are a different size and shape where they enter the head. Thanks to Bill Sherwood you can see pics here http://www.billzilla.org/4agstock.htm#head
The combined area of the two runners in the TVIS manifold is greater than the single runner in the small port manifold, although not twice as much. One runner to each cylinder is held closed at engine speeds below approx 4200 rpm. At higher rpm's the TVIS butterflys will be opened fully by the TVIS valve (servo) to allow unobstructed flow.
At lower engine speeds, closing one runner results in higher air velocity in the single runner feeding each cylinder, giving better fuel vapourisation and improved cylinder turbulance. The result is better economy, and improved low rpm engine performance (more bottom end). As a matter of interest, American V8's used vacuum operated secondaries on 4-barrel carbs for much the same reasons.
After 4200 rpm a single small runner will start to hurt performance, so the TVIS opens to allow full flow for more top end.... the best of both worlds :)
jondee86
Watch this space >>> <<<
jondee86
Postby JT » Fri Apr 30, 2004 5:44 pm
Drifter4ag wrote:TVIS is absolute bad boy ..
so now
Are you running the standard cams? Anymore than a 270 cam and Bil reckon's it's beneficially to remove the T-VIS, does the addition of a turbo change this?
JT
Postby suberimakuri » Fri Apr 30, 2004 8:24 pm
bill hasn't turbo'd a 4age.
I don't know if bill has even built a motor with 270 cams.
DON'T TRUST COMPUTER DYNO'S!
The only way is with proper REAL LIFE Dynos.
It's been tested already.
Keep it in.
Oh...... and a big turbo is going to flow a heap more then 270 cams.
suberimakuri
Postby jondee86 » Fri Apr 30, 2004 9:21 pm
Getting a lung full....... N/A vs F/I :)
One of the methods of improving the performance of a N/A (naturally aspirated) engine is to use camshafts with increased duration. 272 degree cams are about as far as you can go with stock valve gear. Longer duration means greater valve overlap and better scavenging/cylinder filling at high rpm's.
F/I (forced induction) engines rely on the pressure developed by a turbo or supercharger to fill the cylinders, so high lift and long duration cams are not needed. Stock SC or blue top cams will work just fine with a turbo.
Remember that when a turbo engine is not making any boost (at lower rpm's) it behaves just like a N/A engine, and will benefit from the action of the TVIS system.
jondee86
jondee86
Postby matt dunn » Fri Apr 30, 2004 10:30 pm
Basically at low rpm the ports are so large that the iar flow is so slow that the fuel drops out of the air. Closing the tract to one of the ports basically makes the same amount of air go faster past the injector and valve to keep the air and fuel mixed.
So running at 1/2 throttle or if the t-vis butterflies were further away from the head it would reduce power and torque at low speed rpm.
Postby JT » Sat May 01, 2004 1:28 pm
Karl_Skewes wrote:bill hasn't turbo'd a 4age.
Keep it in.
Yeah I knew Bill wasn't turbo'd, I was asking Drifter4ag. Bill has some 288 cams and has rasied the compression to ~10.5:1
jondee86 wrote:Remember that when a turbo engine is not making any boost (at lower rpm's) it behaves just like a N/A engine, and will benefit from the action of the TVIS system.
Now where is the fun in that! :P
If I turbo'd my bluetop I'd be making sure I had a turbo producing boost before 4500rpm. In saying that though, wether I go NA and turbo I will probably keep the T-VIS
JT
