4AGE into a KE70?
4AGE into a KE70?
Postby Rollaman » Tue May 04, 2004 12:25 am
Im looking at doing an engine conversion, 4AGE into a KE70 and was looking for any helpfull tips. Things like what engine mounts are commonly used, ive heard you can use a cross member out of either a TE70 or AE86/85 and use oringinal mounts? Would be good if i could work out what parts i need to at least make a honest start on it.
Rollaman
Postby offensive » Tue May 04, 2004 6:02 am
ae85/86 crossmember should bolt straight on, it did on my te71 neways.
above this is a line
quote: "Reclusive girls dont shave their pubes"
offensive
Postby bridgeport » Tue May 04, 2004 6:58 am
yeah it bolts straight up
www.freewebs.com/corolla_information
my site has some stuff on that conversion
bridgeport
Postby rollanut » Tue May 04, 2004 12:53 pm
yea ae85/ae86 x-member (try to get one without power steering)
t50 or k50 gearbox, for the t50 use a te71 gearbox x-member,
lots of other things to think about too,
fuel pump and line upgrade swirl tank and radiator.
heaps of pther little things will pop up on the way too.
mean as project tho, ke70's handle like go-karts and with some decent
power should be a f**kn wicked ride!.
rollanut
Postby suckymotor » Tue May 04, 2004 2:53 pm
have a ae85 x member for sale
suckymotor
TS Original Member
Postby Scotty » Mon Jun 28, 2004 4:30 am
how much differnt would it be to do it for a ke36
Scotty
Postby Pies » Mon Jun 28, 2004 10:22 am
dont you people know how to use the "search" button? :roll:
Current Rides:
Pies
Postby TURCEL » Mon Jun 28, 2004 11:37 am
Dont forget about the cable clutch to hydrolic if using a T50 box.
TURCEL
Postby Scotty » Mon Jun 28, 2004 2:33 pm
i have searched and couldnt find anything specific, so if u can find a post please tell me
Scotty
Postby phtwgn » Mon Jun 28, 2004 7:26 pm
or use a k50, as theyre cable....but not as strong.
http://toyspeed.blakjak.net/profiles/profile.php?id=785
18 year olds in her prime - manual gx71, haard. FOR SALE. viewtopic.php?t=33980
phtwgn
Postby Suzy » Tue Jun 29, 2004 6:48 pm
What about bellhousings if using a fwd 4age,do u have to use an A series bellhousing on a T50?
Suzy
Postby MetalupYoAss » Tue Jun 29, 2004 10:18 pm
pies wrote:dont you people know how to use the "search" button? :roll:
what are you like wannabe moderator now or something?
MetalupYoAss
Postby MetalupYoAss » Tue Jun 29, 2004 10:23 pm
the only gearboxes you can use are K50 from an ae85 (or another car, but must fit A series motor) or a T50 with an A bellhousing (which will cost you an arm and a leg)
you have one other option which is to get a niteparts W5* gearbox bellhousing (custom) and a w series gearbox... each have theyre strong points.. k50 is cheaper easier to find, cable clutch but its weak...
T50 is stronger but getting hard to find and you'll need to link up a hydro clutch.
w5* are strong as but more expensive and you'll probly need a custom box cross member and drive shaft, might also need to take a ding out of the firewall/box tunnel too but im not sure
hope it helps.. if you want more info PM me ive 4age'd 2 dx's so far :)
MetalupYoAss
