3T-GTEU questions
3T-GTEU questions
Postby dreama » Fri May 21, 2004 10:13 pm
Hey i was wondering if anyone cud answer two questions i have the first is wat is the best turbo to use wen upgrading on this engine and the second question is wat LSD shud i use (the car has a celica 5spd gearbox). Any help wud be appreciated. :D
81 Alfa Romeo Sud Ti
89 Mitsubishi VR4
86 AE82 Corolla FXGT
89 Subaru Leagcy RS
82 TA63 Carina GT-T
89 KS13 Silvia
94KS14 Silvia
86 AE86 Levin
93 EG6 SiR B18CR
97 180sx Type X
(Current) Hunting for new ride.....
dreama
Postby Logan » Sat May 22, 2004 6:55 pm
its all dpeneds opn money, skyline turbos seem to be the go, try using the search tool, its quite amazing...
LSD from supra mk2 will fit, or anything with a F series slipper .diff...
SR Sold. Onto Other Things
Logan
3t turboz
Postby Sicktoy » Sat May 22, 2004 7:13 pm
hey dude...the best turbo to use would be a .63a/r exhaust housing with a t3/t4 turbo setup .. the skyline turbos seem to lack the air above 5500rpm as in feels like theres no power at all! :)
not too good .. the t3-4(to4b) that i have starts boosting from under 2000rpm and hits full boost by bout 2500-3000rpm . i have more than enough air for bout 20psi . are currently upgrading again as i require a bit more air again!
diffs..hmmmmm what car?? IRS or SOLID AXLE??
Sicktoy
Postby dreama » Tue May 25, 2004 2:29 am
The car is a 82 TA63 Carina GT-T not sure wether its ISR or fixed but i have a feeling that its similar to an AE86 rear as the use very similar strut set ups
89 Mitsubishi VR4
89 Subaru Leagcy RS
82 TA63 Carina GT-T
89 KS13 Silvia
94KS14 Silvia
86 AE86 Levin
93 EG6 SiR B18CR
97 180sx Type X
dreama
Postby wde_bdy » Tue May 25, 2004 4:14 pm
It will be IRS, have a look under the back of the car where it will be pretty obvious. Most likely to be an F292 (check your chassis plate) which is very different and a lot stronger than the AE86 diff. MA61 is the best source of LSD if you can find one, or they can be purchased new.
Callum
wde_bdy
3t
Postby Sicktoy » Tue May 25, 2004 7:42 pm
yeah sure willl be an IRS all ta63s are ...if your lucky it might be a LSD bt i doubt it really :) the one i had wasnt ,,, wasa f292 4.1:1 Open centre
Sicktoy
Postby dreama » Wed May 26, 2004 7:50 pm
Cheers for the help :lol: will put it to good use. I had assumed that it might be IRS but wanted to double check as i havent got the car yet. thanx
dreama
Postby AE25 » Fri Jun 04, 2004 10:23 pm
ta63 with 3tgte sometimes have the F series irs lsd too.
umm im confused... sicktoy a t25 has a .49a/r turbine (i got one to prove) and t28 are usually .64a/r aren't they.. so a t3 with .43 exhaust? typo maybe?
zoom mag did a comparison on the nissan/garrett turbo's
http://members.iinet.net/~sayers/biscuits/turbos.htm
E2 & E7 fanatic
http://www.toycrazy.net
AE25
typo
Postby Sicktoy » Sun Jun 06, 2004 9:04 pm
ae25: yeah dude that definatly wasa typo :) geez .43 hehe obviously werent payn attention :)
Sicktoy
Postby AE25 » Mon Jun 07, 2004 2:46 pm
heh heh
going on other peoples comments and conversions a garrett t3 size turbo seems the go
im just gonna put a t25 on to start with just to replace the std ct20 coz it chews through the oil... i burn off 2ltrs of oil in a week driving from auckland- palmerston and back then to taupo the next weekend and it was off the dipstick! the t25 i have is off a rb20et r31 passage gt skyline. not the best of replacements but should flow enough to keep me going. don't want to have heaps of boost to start with anyways
E2 & E7 fanatic
AE25
Postby dreama » Tue Jun 08, 2004 11:58 pm
Kool thanks again. Other recomendations ive had have been the T28, CT26(single entry) or the turbo off a Caldina GT-T (unsure wat this is). R any of these turbos able to be bolted straight on (my guess is no) if not then wat mods will i be looking at making to have it fit? :lol:
dreama
Postby AE25 » Wed Jun 09, 2004 1:49 am
i don't know of any direct replacements for the ct20.
usually an adapter plate is made to mate the std exhaust manifold to an upgraded turbo. yeah all of those should be a good choice too for responsive turbo and a mild boost increase since they're originally from 2ltr engines
E2 & E7 fanatic
AE25
Postby wde_bdy » Thu Jun 10, 2004 11:22 am
The single entry CT26 from the 7M-GTE is the nearest "bolt-on" fit. Just need to slot the mounting holes in the turbo flange and it bolts on. However, you then need to get the core rotated so the oil drains properly and make a new drain pipe. Fairly straight forward though, assuming you can find a turbo in good condition.
Callum
wde_bdy
Postby dreama » Thu Jun 10, 2004 11:31 am
Yea i thought the CT26 wud be the obvious choice to only prob is finding one in they're near impossible to find in any sort of decent working order. So i thought the next best option could be the T28 as is easy to find and very reliable
dreama
Users browsing this forum: Bing [Bot] and 16 guests
