Things to watch for?
Thinking of using one on an EZ30 (3.0L flat six engine) with Variable Valve Timing to stretch the useable powerband...
yes I'm a novice, and yes the tuning will go on a non-turbo...
Any advice/opinions much appreciated.
RedMist wrote:Most aftermarket ECU's will claim VVT or VTEC control. However they generally use simple RPM triggers. The standard VVT advances the cam based upon engine temp, load and RPM.
dohca wrote:RedMist wrote:Most aftermarket ECU's will claim VVT or VTEC control. However they generally use simple RPM triggers. The standard VVT advances the cam based upon engine temp, load and RPM.
Is this really relivent with a stand alone system tho?
you can change fuel ratios all that kinda crap already rather than the computer deciding on when to change etc.
