blacktop aftermarket extractors
Postby qik20v » Wed Jun 02, 2004 5:42 pm
has anyone actually bought and tested (on a dyno) any aftermarket extractors for a 4age blacktop?
or are the standard ones good enough that there is no point in buying aftermarket?
1996 AE111 Toyota Levin BZ-G - 15.1 @ 146km
http://toyspeed.blakjak.net/profiles/profile.php?id=301
qik20v
Re: blacktop aftermarket extractors
Postby Monsterbishi » Wed Jun 02, 2004 6:13 pm
qik20v wrote:has anyone actually bought and tested (on a dyno) any aftermarket extractors for a 4age blacktop?
The factory ones are as good as they get short of paying a fortune for mandrel bent tuned length/volume extractors...
--- Cut Here ---
'94 JDM Ford Mustang GT Coupe
Monsterbishi
Postby MetalupYoAss » Wed Jun 02, 2004 6:25 pm
toyota have lots and lots of money to spend on research and development of theyre engines, your pretty much throwing your money away if you go buy some aftermarket jobs..
MetalupYoAss
Postby FLAWLES » Wed Jun 02, 2004 6:50 pm
I WOULD HAVE TO AGREE
THE STANDARD BLACKTOP ONES DO THE TRICK
there are some real trick trd ones tho
FLAWLES
Postby B_giB » Wed Jun 02, 2004 8:33 pm
i know woith the red top 4age the factory manifold was good for 200 kw or somethin
Current: SXE10 Altezza
Previous:AE86 Trueno Notch Back: Gone but not forgotten :cry: :(
AE101 Levin 20V super strut
1994 Mercedes Benz C280 Sport
B_giB
Postby Mr Revhead » Thu Jun 03, 2004 2:36 pm
yeah the stock ones are good unless youv spent a small fortune on ya engine
Postby TRD Man » Thu Jun 03, 2004 3:40 pm
Those who have stated that the std item is good are quite correct. They're probably better than most after market extractors.
Like all OE they can be improved on & it needn't cost a fortune.
We sell a set of extractors for 20V which were locally designed, tested & manufactured.
They were designed for silvertop. We supplied the car for the dyno testing so we know the results are true & correct.
In a completely std silvertop AE101 these produced a 12hp gain.
In a customer's blacktop AE111 they produced 5hp.
TRD Man
Postby Mr Revhead » Thu Jun 03, 2004 3:49 pm
what do they dp to the torque? thats probably more important in the 20vs than out right h/p
Postby Blkwinter » Thu Jun 03, 2004 3:51 pm
TRD Man wrote:Those who have stated that the std item is good are quite correct. They're probably better than most after market extractors.
Whats the price on these?
Blkwinter
Postby TRD Man » Thu Jun 03, 2004 4:13 pm
Including GST & freight about $400 depending on where you are.
TRD Man
Postby Mr Revhead » Thu Jun 03, 2004 4:17 pm
trd man... just wondering why you still claim to be the sole trd agent in nz??
Postby offensive » Thu Jun 03, 2004 4:42 pm
yeah standard ones are good, look real pretty n stuff.. until u see the bit thats underneath where they combine to one, oxy sensor is there also and is covered in a heat sheild. that bit gets squished up nastey.
above this is a line
quote: "Reclusive girls dont shave their pubes"
offensive
Postby qik20v » Thu Jun 03, 2004 11:09 pm
so is it a good idea to replace the secondaries?
or just the piping after the final collector (the squished part)
qik20v
Postby MattrickMotorsport » Fri Jun 04, 2004 8:30 pm
Mr Revhead wrote:trd man... just wondering why you still claim to be the sole trd agent in nz??
get over it! :roll:
MattrickMotorsport
Users browsing this forum: No registered users and 75 guests
