Ae86 t50 - 20 or 22 spline?
Postby ~SlideWays~ » Fri Jun 11, 2004 1:32 pm
yup just need to know if they are 20 or 22 spline? (pretty sure thats the difference)
~SlideWays~
Postby Mr Revhead » Fri Jun 11, 2004 1:49 pm
i believe the ae86 ones are 22 spline and te70 etc 20 spline
Splines
Postby crispy'86 » Sat Jun 12, 2004 12:58 pm
The AE86 T50's have 22 splines on output, TE71 have 20 spline pre 82, 83 TE71 have 22 splines output, i've got one in my AE86 out of an 82/83 TE71 Sprinter and driveshaft hasn't been changed. Had to compare it a while ago with a 20 spline yoke and didn't fit the output on g/box in car
crispy'86
Postby ~SlideWays~ » Sat Jun 12, 2004 1:54 pm
Sweet looks like i've got a spare t50 then 8) ....unless there is a split case gbox that looks exactly the same?! 8O
~SlideWays~
Postby rxtoy » Sat Jun 12, 2004 7:00 pm
they're all T50's (T40's look the same too), just the earlier one's had a 20 spline output and the AE86 one's (i'm pretty sure they were AE86 only) were 22 spline and they're meant to be stronger. i think the TE7* one's would have the same length driveshaft (based on the same platform???) so if you've got a 20 spline output on your T50 try and find a driveshaft out of one of those,
Matt
current rides:
76 stout
77 B1600 13B J port
rxtoy
Users browsing this forum: No registered users and 70 guests
